Fuel System Rated For 600 WHP
Old Oct 25, 2009 | 07:26 AM
  #21
ERL_S2000's Avatar
Originally Posted by Tech7427,Oct 25 2009, 06:41 AM
just for your fyi..
this is what you need to go from the oem hard line to -6
http://www.summitracing.com/parts/EAR-165056ERL/
Just ordered one since I am going to be needing it. I have a in tank Walbro I using to start with. I have a GT30R thats going on to start with before the 6262. I wanted to break this clutch in have some fun get all the bugs out before I really step it up past 550whp. I figure that the stock rail is fine right now.
Old Oct 25, 2009 | 09:47 AM
  #22
dsddcd's Avatar
That is not the correct part, that is designed for soft aluminum tubing not the hard steel we have.
What you need is a -5AN Tube Nut and don't for get the sleeve.
http://www.summitracing.com/parts/AER-FBM3571/
You will also need a 37 deg (JIC) Flaring Tool
http://www.summitracing.com/parts/SUM-900311/
Here are some pics I took while installing the tube nut, but it is very easy.
Cleanly Cut
Debur
Double Flare
Pressure Test
Old Oct 25, 2009 | 10:01 AM
  #23
ERL_S2000's Avatar
Thanks! What size line are you running to the rail?
Old Oct 25, 2009 | 03:55 PM
  #24
DeadZero's Avatar
i made 600.
Bosche saturated injectors 1000cc
walbro fuel pump
Methanol injection.
And a BAD ASS TUNER!!
Old Oct 25, 2009 | 05:55 PM
  #25
Tech7427's Avatar
im not quite sure why you dont agree? ive been using this setup on my integra and alot of other hondas running the 5/16" feed like which is -5an..
Old Oct 25, 2009 | 07:19 PM
  #26
dsddcd's Avatar
I ran -6AN from the rail to the hard line
Yes, I am sure it can work but I go only by the book
Old Apr 15, 2010 | 07:19 AM
  #27
SC_Highlander's Avatar
Bumping this up to ask a question.... are the stock feed and return hard-lines the same size? 5/16ths?
Old Apr 15, 2010 | 08:32 AM
  #28
Irishflame27's Avatar
no the feed is 5/16ths and the return is about 1/4
GEARHEAD
Aug 3, 2016 12:30 PM
lopez14
Mar 21, 2013 08:00 AM
TonysMI4
Aug 29, 2011 10:10 AM
GDM S2K
Mar 15, 2006 01:56 PM
