Fullblown Radiator Questions
Old Jun 27, 2013 | 08:18 PM
dsddcd's Avatar
Default Fullblown Radiator Questions
I have a few questions for those who have installed a Fullblown radiator. I like the radiator, it came in with no issues but there are a few things that some small mods may make it easier for everyone to install.
1.) Were you able to reinstall the rear under tray?
----On my 2001 the lower tank was too low thus I was unable to push the clips back in.
2.) Were any modifications required the OEM fans?
----Both my 01 and an 06 I was involved with the lower tabs were about a 1/2" too close to the upper and had to be bent.
3.) Any issues with the temperature sensor?
----The late model sensor was much smaller diameter and a fitting had to be made to work with the supplied threads.
4.) Did you put a seal between the upper tank and steel support like the OEM had?
5.) Anyone get an aftermarket cap, mine was vary tight.
Old Jun 27, 2013 | 08:49 PM
jordannn93's Avatar
I was going to get an aftermarket cap but I never did. The cap they sent worked fine for the few months that its been in the car.
Old Jun 27, 2013 | 08:57 PM
s2000Junky's Avatar
The only thing I had to do was play with the fan shroud spacing a little bit and cut a notch out for my after cooler to fit for my Comptech kit because everything sticks out further. Everything else was plug and play. I was impressed how easy it all went together.
Not sure why you bothered to remove the under tray? It can all be done from above.
Old Jun 27, 2013 | 09:20 PM
ktpp35's Avatar
im contemplating getting a fullblown radiator myself, how much is it an improvement over the stock one with a turbo setup?
Old Jun 27, 2013 | 09:37 PM
redboost10's Avatar
It's just a mishimoto radiator. A good upgrade from oem
Old Jun 27, 2013 | 09:49 PM
mr-pitts's Avatar
If it isnt covered in dents, badly scratched with a crap filler cap then its not a real Fullblow radiator.Also if you email them and tell them then that proves its not a real fullblown radiator because I never got a reply.
Old Jun 28, 2013 | 05:22 AM
miguel329's Avatar
Call the shop they always pick up kinda hard to email 1000+ dumb question emails a day... also my full blown rad came perfect... lj always has great customer service...
Old Jun 28, 2013 | 09:58 AM
s2000Junky's Avatar
Sounds like you had some bad luck.
Old Jun 28, 2013 | 10:46 AM
razzele's Avatar
I've been meaning to call them about the FBM throttle body I received. Sticky as fuxk, butterfly rubs on the body
Old Jun 28, 2013 | 12:53 PM
miguel329's Avatar
Call lj he has always fixed any issues I've had.
