fuse box relocation
Old Jan 11, 2011 | 03:57 PM
darektylka's Avatar
Default fuse box relocation
I have a gt3076r turbo with pfab lof manifold and my fuse box is currently few inches away from turbo heat wrapped and just want to know if there is a relocation kit??
Old Jan 11, 2011 | 07:16 PM
Alloy Craft's Avatar
Former Sponsor
I was thinking about designing one, if there was enough interest. I think it would go nicely with our heater valve relocation bracket.
https://www.s2ki.com/forums/index.php?showtopic=829128
Old Jan 11, 2011 | 11:26 PM
darektylka's Avatar
where you thinking?? somewhere on the firewall
Old Jan 12, 2011 | 12:57 AM
Ben J's Avatar
I'd be interested in a kit. I'll be working with Neukin Motor Development on a new S2000 manifold soon and it will require the fuse box to be moved. SO... Alloy Craft soon as he gets the manifold done, he can place info for your fuse box kit if you make one on his site to go with the manifold. Just a thought. Lil cross marketing there, lol.
Old Jan 12, 2011 | 04:13 AM
s2kdan05ems's Avatar
I have lht bracket for my fuse box 50 bucks shipped, I have pfab log kit too it works fine doesnt get real hot cause I coated the mani and down pipe and have a turbo blanket which is all you need. pulse when you run into problems you dont wanna pull your fender off to check a fuse or a relay. I had these issues already so thank god I didnt put in the fender. I have pic Ill bump tread so you can see it, Gt3076r pfab log i think is the thred name
Old Jan 12, 2011 | 04:24 AM
hey man i wanted to ask you not to knock your bracket or anything because it is really nice but do you even need the valve there anyways cause I just deleted mine and cut the house and put it to the line and my heater works fine, so the real question is whats the point of the valve?????
Old Jan 12, 2011 | 05:16 AM
kevos2k's Avatar
the valve is how you control hot/cold to your heater it opens and closes based on the knob in the car blue to red
Old Jan 12, 2011 | 05:54 AM
o'malley_808's Avatar
^ lol yeah you must be cooking in your cabin having the heat on 100% all the time
Old Jan 12, 2011 | 05:56 AM
boostedf22c's Avatar
You don't need that valve at all really. All it does it close when you have the A/C on so it's not circulating hot coolant through the heater core while your A/C is on. I didn't run one at all and my heat was hot and my AC was ice cold. Now I'm sure if you put a thermometer on the vents when the AC was on it was a couple degrees warmer that it could be, but it was still very cold.
Anyways, here is a link to a thread with a fusebox relocation idea.
https://www.s2ki.com/forums/index.php?showt...0&#entry9000743
Old Jan 12, 2011 | 06:44 AM
cboyarskirn's Avatar
I would be interestedin the fusbox bracket
umair
Nov 5, 2015 05:01 PM
Suzuka_Joe
Jun 22, 2011 03:23 PM
AndyFloyd
Nov 8, 2007 04:45 PM
