Gauge question
Old Oct 26, 2009 | 03:27 PM
RL1924's Avatar
Default Gauge question
So im a total newb have come a far way but still have much more to go in FI..
I was told by my tuner it would be a good idea to run a wide band with "0-5 volt output wire for datalogging"
I was looking at this prosport gauge was wondering if anyone could help me out does this work for what he said? Is it a decent gauge?
http://prosportgauges.com/wideband-a...ratio-kit.aspx
Thanks for any info
Old Oct 26, 2009 | 03:38 PM
spectacle's Avatar
That should work depending on what solution you use for datalogging...what are you going to use?
Old Oct 26, 2009 | 03:42 PM
RL1924's Avatar
Ill probably be using the AEM if thats what you mean
Old Oct 26, 2009 | 03:51 PM
spectacle's Avatar
Call prosport and find out if the wiring harness has two 0-5 volt outputs. You'll need one to go to the gauge and one to go to the AEM. If not, you could splice it, but I dunno how that might affect the reading(s)
Old Oct 26, 2009 | 03:57 PM
RL1924's Avatar
Ok cool appreciate the help
Old Oct 26, 2009 | 05:03 PM
AusS2000's Avatar
I use the AEM sensor/controller wired into the AEM EMS and have the AEM Serial gauge to display all sorts of parameters from the AEM including A/F.
Old Oct 26, 2009 | 05:08 PM
dsddcd's Avatar
Don't forget about PLX and Inovate both are very nice.
Old Oct 26, 2009 | 07:31 PM
jari8378's Avatar
I am using the AEM Uego.. linked to the another management system... it works great.
jdms2000f20c
Mar 23, 2012 02:27 PM
jordannn93
Mar 18, 2012 08:16 AM
TelosHedge
Aug 18, 2009 08:38 PM
ZSAK
May 19, 2008 07:24 AM
kleecker
May 17, 2007 12:45 PM
