Which gauges are most important?
Old May 21, 2013 | 02:28 AM
JayC07's Avatar
Default Which gauges are most important?
Was going to buy the SOS gauge pod and wanted to know which gauges to buy? Boost/ afr/ oil pressure etc... its only a dual pod tho so I'm not sure what the most important ones would be... or what other pods are out there that will allow me to see more of whats going on... sorry im a noob...but trying to learn!
I have an sos charger btw
Old May 21, 2013 | 04:17 AM
GrandMasterKhan's Avatar
Wideband a/f and boost. You could also do a multi-gauge which displays more than one value.
Old May 21, 2013 | 04:31 AM
CoolGuy094's Avatar
I would suggest the AEM Wideband Failsafe gauge, as it is one gauge that clearly and simultaneously displays AFR and boost. It also has data logging capabilities.
http://www.aemelectronics.com/wideba...safe-gauge-84/
Old May 21, 2013 | 05:19 AM
depending on how you planning on driving. I personally feel oil temp is quite important and often over looked.
Old May 21, 2013 | 06:39 AM
Prokaw875's Avatar
I have a AEM EMS V2 on a P-TUning kit and run the same SOS dual pillar pod with a AEM AFR and AEM Digital Boost guage. BUT... If i was to do it all over again I would get a Stack Gauge and replace the cluster and have every guage direct off the dash display. At min. just get a serial gauge and oil pressure guage too.
Old May 21, 2013 | 08:06 AM
JayC07's Avatar
Hmm.. Well I mostly use my car as a WW/Car cruises/LIGHT track duty. That Failsafe looks awesome tho... I'm just not sure what would best suit me!
Failsafe + oil temp? OR A/F + Boost ....If someone can link me with gauges I SHOULD have ( and with a low price) I'd appreciate it
Old May 21, 2013 | 10:50 AM
CoolGuy094's Avatar
See that's the thing... Why spend money on an A/F gauge and money on a boost gauge when you can combine that money, get one gauge in the Wideband Failsafe, and have the open pillar spot for another useful gauge??? Or just rock a single gauge pillar pod like me!
I use my phone and Torque Pro to monitor other OBD2 sensors, etc.
Old May 21, 2013 | 10:59 AM
Phill24's Avatar
Air fuel oil pressure or fuel pressure
Old May 21, 2013 | 08:34 PM
JayC07's Avatar
I ended up going with a wideband and oil temp
Old May 21, 2013 | 09:44 PM
redboost10's Avatar
oil pressure oil pressure oil pressure. im surprised only one other person has recommended oil pressure.
