Which gauges are most important?
Old May 22, 2013 | 04:45 PM
  #21
redboost10's Avatar
Does aem not have cuts?
Old May 22, 2013 | 06:32 PM
  #22
Phill24's Avatar
How do u guys feel about the racpak dash?..is it worth buyinh for a street car?
Old May 22, 2013 | 07:25 PM
  #23
redboost10's Avatar
Racepak or aim. I believe their basic model is about 600. That's just a display only price, I may be wrong. Once you start adding features, logging, inputs/outputs the price goes up. there is an interface for aem as well
Lots of options though as for warning lights, shift lights, and what values to display.
I run the motec cdl3 and love it. We have a basic racepak on our rwd escort.
Old May 22, 2013 | 08:42 PM
  #24
hybrdthry911's Avatar
As far as I know AEM EMS can't be directly configured to cut Ignition if Oil pressure drops too low directly. You can wire up the sensor but only view/log it not use it to affect the tune in any way. Only a few sensors have the ability to affect the tune, such as IAT, ECT, EGT, AFR and a few others. You would need a separate device to read the sensors, decide the requirements, and then ground out/power an input to the EMS. Even with a direct input like that you have limited options on what you can do using the nitrous maps, 2 step rev limiters, and boost control if you are controlling boost with your AEM EMS.
Old May 24, 2013 | 01:26 AM
  #25
You can put a boost cut into your ecu as well as a oil pressure cut. Only way to go in my opinion
I guess you lit a fire under my butt. I added the trigger outputs for the transmitter, so now my warnings can be configured to output to the AEM EMS and trigger a boost or ignition cut. You can setup minimum oil pressures for various RPM points. You can setup maximum AFR readings for various Boost readings, coolant temp protection, etc. Any sensor the AEM can read you can setup a warning and a trigger to cut the engine.
Old May 24, 2013 | 06:08 AM
  #26
redboost10's Avatar
Awesome. I know aem is cost effective but these standard capabilities with motec makes it top notch.
Those cuts can save you 5-12k or whatever your engine cost.
Old Jun 3, 2013 | 12:08 PM
  #27
crb5885's Avatar
i run boost and AFR on the A pillar and then egt, oil temp, oil pressure and coolant temp in cups on the dash. I didnt want to over look anything vital.
Old Oct 9, 2013 | 10:02 AM
  #28
desii's Avatar
I hate to bump this up but i have ran into a few questions about gauges and i cant seem to figure out an answer (ive been searching for a week or so)
I have a 2006 s2000 with SOS youtune kit. Ive decide to get at least an AFR and oil pressure gauge. (probably plx multi gauge)
Now my tuner/shop told me that the 02 sensor on the DBW ap2s can read wideband air fuel ratios. is this true? would i still need to get a new 02 sensor and stuff when getting a gauge or can i somehow tap into this 02 sensor?
Can I monitor any of these two from my OBD2 through a phone app? (i have looked up torque app my friend recommended, but i cant seem to find an answer if AFR or oil pressure is displayed from the obd2)
hope someone can chime, Thank you!
Old Oct 10, 2013 | 07:40 AM
  #29
jordannn93's Avatar
Afr, oil pressure and water temp
Old May 15, 2014 | 06:54 PM
  #30
sillyboybmxer's Avatar
does anyone know how they mounted their guages like this(its not on Modifry)
Chiung
Jun 6, 2015 03:36 AM
bgioan
Oct 18, 2013 01:48 PM
KiNgKoNg723
Apr 16, 2012 06:41 PM
Shftat9k
May 24, 2009 09:01 PM
GpWaP1 s2k
May 18, 2009 06:32 PM
