Which gauges are most important?
Old May 22, 2013 | 01:50 AM
raikouS2K's Avatar
PLX DM-100
I saw this on another gauge thread. This is the route I am going with along with a SOS single gauge pod. There are so many options you can do with these gauges and up to four readings at once. Also, they have different screen layouts, even one that matches our tach. They have wideband and "daisy" chainable sensor units all for one gauge.
Old May 22, 2013 | 02:31 AM
cmn's Avatar
cmn
Originally Posted by redboost10
oil pressure oil pressure oil pressure. im surprised only one other person has recommended oil pressure.
I'm actually quite surprised as well. Personally I have boost, oil temp, oil pressure and AFR. Here is my setup (the AFR gauge is placed where the red circle is, angled towards the driver spot):
Old May 22, 2013 | 01:36 PM
GrandMasterKhan's Avatar
I have wideband, oil temp, oil psi, boost, water temp, and ambient air temp (all except for one steahtly hidden)
Old May 22, 2013 | 03:15 PM
wy2slow_z's Avatar
as many have posted. IMO afr/oil pressure are the important ones.
bad picture but afr is in the radio door, boost/oil pressure/water temp in the dash.
Old May 22, 2013 | 03:40 PM
hybrdthry911's Avatar
Oil pressure is great but it's usually too late once you realize you lost oil pressure, hard to keep an eye on it all the time. Honestly I rarely look at mine. I'd put it behind boost and AFR on my list.
Old May 22, 2013 | 03:42 PM
redboost10's Avatar
I have mine wired to a set minimum then it starts blinking. So it's not too late
Old May 22, 2013 | 03:48 PM
redboost10's Avatar
You can put a boost cut into your ecu as well as a oil pressure cut. Only way to go in my opinion
Old May 22, 2013 | 03:51 PM
herecomesboost's Avatar
What is your minimum setting, if you don't mind sharing?
Old May 22, 2013 | 04:17 PM
Phill24's Avatar
How mine is setup...everything is directly in my face i normally look at all my gauges before and after a pull
Old May 22, 2013 | 04:33 PM
An alarm type of gauge is good or a passive cut type would be best for oil pressure like you said redboost.
I'm going to be working on configuring outputs to trigger cuts for my advanced warning system in my ios app. Overboost, low oil pressure, over temp, lean protection, etc
