Getting new turbo
Old Jul 26, 2011 | 06:18 PM
LesterJ's Avatar
Default Getting new turbo
I got a 01 s2k already turboed by the previous owner and i went and had a tune last weekend. I ended up with 348whp and 240lbs torque but everytime we did a pull he said my turbo was getting weaker and it would smoke really bad. We are assuming turbo is going bad. I just wanted to get any suggestion people have on turbos. All i know about my current ebay cheap turbo is .64hotside .50 a/r cold. I would like to make it up to 400 whp and try to stay around $800 or so. I have been looking at this turbo
Old Jul 26, 2011 | 07:09 PM
DFWs2k's Avatar
t3 or t4?
Old Jul 26, 2011 | 08:01 PM
Suzuka_Joe's Avatar
that turbo is too little, we need to know more info. What manifold do you have and how much power/boost do you plan on making? also what are the supporting mods? injectors, downpipe size, fmic size?
a precision 5857 is perfect for hitting 380- 400 around 10-12psi on a good tubular manifold. They are in your budget if you get journal bearing. I have a ball bearing 5857 .63ar and I made 423whp on 13psi with my old mase kit
Old Jul 26, 2011 | 08:42 PM
passmans2kny's Avatar
i agree a journal 5857 is ur best bet for the power u want and how much u wanna spend
Old Jul 27, 2011 | 11:00 AM
camuman's Avatar
More info on setup. 5857 Is great bang for the buck.
Old Jul 27, 2011 | 12:23 PM
LesterJ's Avatar
38mm external wastegate, Inline pro manifold t3 flange, PrecisionProo 600HP intercooler kit. 3' megan racing exhaust no cat or resonator, Walbro 255 fuel pump, AEM EMS 30-1052 computer, 2mm head gasket, greddy type s blow off, 750cc RC Engineering high impedance injectors, 3bar map sensor, AEM fuel pressure regulator. ALso needs to be 5 bolt
Old Jul 27, 2011 | 03:22 PM
camuman's Avatar
Bleh to hg. Def 5857 though. Will be really nice.
Old Jul 27, 2011 | 05:44 PM
Revenge's Avatar
Don't cheap out, if you have a inline pro manifold you will need a B housing or you will need to cut into your frame. So consider there 5865b or a gt30 in the b housing. If you want to notch then get the turbo mentioned for quick spool or the 6262 or gt35 for more high end number and run around 16psi IMO.
Old Jul 27, 2011 | 05:55 PM
Suzuka_Joe's Avatar
Inline log manifold? can't use a 5857 then... I'd sell the hot side and injectors you have and get a good tubular hotside and ID1000 injectors
omarisramo
Aug 24, 2012 08:20 PM
PndaS2K
Jun 17, 2012 08:10 AM
ftpsk8
Aug 5, 2011 03:28 PM
minhdinh85
Mar 13, 2009 09:36 AM
s2k54
Dec 27, 2008 07:08 PM
