GM 3BAR MAP
Old Nov 5, 2008 | 01:42 PM
jwa4378's Avatar
Default GM 3BAR MAP
Hey everyone-
I bought a new GM 3BAR MAP sensor that I want to install this weekend. I also got a generic GM plug, which is pig-tailed, which I intend to solder into the OEM harness (cut OEM clip off harness, and solder harness to new GM MAP clip).
Here is the unit I bought:
In the picture above, from left-to-right (PIN 1, PIN 2, and PIN 3) on the plug receptor that is on the sensor, which is the positive in, map lead, and ground?
I have an OEM manual, so I can find out which is which on our stock harness, but its just a matter of what PIN on the GM harness to solder the wire to....
Thanks again!
John
Old Nov 5, 2008 | 04:54 PM
timg's Avatar
http://www.hondata.com/tech3barmap.html
http://www.turbobuick.com/forums/alcohol-n...wiring-faq.html
Tim
Old Nov 5, 2008 | 05:06 PM
jwa4378's Avatar
Thank you much! Exactly what I was looking for!
timg - Seeing as you know about AEM too... I know that the GM MAP sensor is already pre-calibrated within the EMS as an option. Where is the menu to change from the OEM MAP to the GM MAP? I want to say I saw it when my tuner last looked at the car about 6 months ago, but I am not 100% sure where it was located... I want to have everything lined up to go when I get to cutting...
Thanks again, man!
John
Old Nov 5, 2008 | 07:31 PM
Kirpich's Avatar
Wait, that Hondata link says that a 3-bar can read up to 28 psi... What the? One bar is equal to 17 psi. so simple math tells me... Umm... not adding up here....
Old Nov 5, 2008 | 07:38 PM
godmachine's Avatar
1bar is 14.5-14.7psi
Old Nov 5, 2008 | 08:55 PM
Kirpich's Avatar
Ok, I stand corrected... But that still translates to 2 bar, not 3!
Old Nov 6, 2008 | 08:18 AM
jwa4378's Avatar
NA sea level pressure is 1 BAR. 2 more BAR in top of that = 28-30psi.
John
Old Nov 6, 2008 | 03:44 PM
timg's Avatar
Settings > MAP Sensor > Wizard
Tim
Old Nov 7, 2008 | 04:41 PM
jwa4378's Avatar
Awesome! Going to install this bad boy and my electronic boost controller tomorrow.
Going to a dyno day on Nov. 22 here in town. I hope to be at 400+ by then!
I've been a slacker.
John
Old Mar 28, 2009 | 02:10 PM
ap2s2k505's Avatar
Hey let me have the S wiring for the map
AZ-S2000
Mar 23, 2013 05:13 AM
rjbecker12
Oct 5, 2012 08:29 AM
nexus
Forced Induction For Sale
Feb 21, 2012 10:30 AM
jaundice
Feb 23, 2010 08:30 AM
ap1chick
Oct 12, 2008 09:09 AM
