going for 400BHP+?
Old Dec 22, 2006 | 12:20 PM
danw's Avatar
Default going for 400BHP+?
My car is running stock Vortech supercharger with a Toda 2.2l low compression stroker kit. Everything else is stock and the cat is still on. It makes just under 300 RWHP now I was thinking to take the cat off and change the pulley to 4" for 12.50 psi boost about double what it is now. So 350RWHP/400BHP+ is the rough target, is this realistic?
I know there can be clutch problems so the clutch has been changed but will anything else need doing?
Old Dec 22, 2006 | 02:31 PM
Nhan's Avatar
with 12.5 psi, you should be well over 350whp, i'm at 9psi right now and i'm hitting 345whp on a dynodynamics..
Old Dec 23, 2006 | 10:08 PM
TheCarGuy2021's Avatar
How's your low end power/torque with S/C and being stroked? Any noticeable difference?
Old Dec 25, 2006 | 07:38 AM
danw's Avatar
heres my dyno, bottom end torque does feel better driving. I was a bit dissapointed with the results but then I guess the low compression stroker kit on its own doesn't do much it just means you can run a lot more boost
Old Dec 25, 2006 | 02:10 PM
Oh the possibilities... Good luck with everything!
Old Dec 25, 2006 | 06:54 PM
mase1's Avatar
just be very careful with the intake temps on higher boost
Old Dec 25, 2006 | 06:59 PM
Enthralled's Avatar
head gasket.
Old Dec 25, 2006 | 09:25 PM
Jekyoo_Style's Avatar
Originally Posted by ENTHRALLED,Dec 25 2006, 09:59 PM
head gasket.
a headgasket isn't needed since he already has low CR from the stroker.
Old Dec 28, 2006 | 11:58 AM
danw's Avatar
my cars in england so its usually cold and the vortech has the aftercooler but have you got any other tips?
Old Dec 28, 2006 | 12:48 PM
s0rted's Avatar
^ yes, up the boost already Seriously though, you might want to go a step or two colder with your spark plugs. good luck!
Nadroj952
Mar 11, 2015 09:08 AM
s2konroids
Sep 19, 2010 09:18 AM
tofuboi84
May 26, 2008 12:15 AM
VortechS2k
Mar 18, 2003 04:45 AM
