going back to stock form
Old Nov 19, 2006 | 08:07 PM
icemans2k02's Avatar
same thing happend to me the black box that went under the aftercooler, had a vac line that was kinked when it was looping under the box, simple fix but VERY annoying
good luck to you
Old Nov 19, 2006 | 08:12 PM
LudeAtic's Avatar
so the vac line was just kinked (as in squished?)
how did you fix it?
Old Nov 19, 2006 | 08:15 PM
just had to pull some slack in the line, just look very closely, after install i got very eager and was bugged by the CEL. just take your time and comb on line at a time and you should find it, post pics of your bay as well and we may be able to offer some insight if the guys rerouted a hose by accident
Old Nov 20, 2006 | 10:27 AM
LudeAtic's Avatar
noob question:
from the link of https://www.s2ki.com/forums/index.php?showtopic=105368
the top line (#1 pic) goes straight to my godzilla bov? thats how mine is at right now.
Old Nov 20, 2006 | 05:44 PM
SIIK2NR's Avatar
It should connect at a y gate and look like this...
Tim
Old Nov 21, 2006 | 12:22 AM
LudeAtic's Avatar
think that is how mine is like and still getting the code....
Old Nov 21, 2006 | 12:27 AM
Enthralled's Avatar
why don't you take a picture of your vac lines and post it so we can see.If it makes you feel any better P0411 is a harmless CELL.won't damage your car in any way.
peace
Old Nov 26, 2006 | 08:09 PM
LudeAtic's Avatar
so i checked all the lines and i dont see any tears or rips. I searched on the forum and someone did run a code P0411 and it had identical problems as i have right now.
I can clear the code and it wont come on for a good 12-24 hours. When the engine gets cold and i turn on the car, it pops on again. I mean, if the car was warmed up, then there is no problem but the CEL only comes on when the engines "gets" warmed up.
could this be that the inside of the vacuum lines are bad? if so, can i just change those out and it would fix the problem?
Old Nov 27, 2006 | 04:57 AM
civicguyinva's Avatar
Its a 2 trip sensor. You have to make two cold starts for the light to come back on. I finally found the hose on my car that was causing the same code. Apparently last time I was at a shop they undid a few zip ties and the hose got too close to the pulley and the pulley got mad at it and bit it. Hopefully you have just a simple problem like a cracked hose or something loose.
s2kprax
Jul 31, 2018 06:38 PM
madmaxblaster
18
Feb 10, 2014 08:15 PM
Fujin
19
Mar 23, 2011 07:25 AM
s2kswe
Jul 27, 2010 10:54 AM
flag2carrot
Feb 3, 2008 07:34 PM
