Going E85
Old Jun 18, 2011 | 11:43 AM
Corey Maurer's Avatar
Default Going E85
Okay so the car goes to Evans on the 29th, and I just decided I want E85 lol
Going to be ordering
FB340 Fuel pump to replace my walbro (just called FullBlown they said it will flow over 600WHP on E85 which is more than I need )
Injector Dynamic 1000CC injectors
Stock Fuel Rail tapped for gauge
AEM Fuel Pressure Regulator (The one listed under the part number from AEM on Summit only says 20-60psi? Is this a mistake on their part? Im going to need to flow 90-100 for this setup)
Fuel pressure gauge
Im shooting for as close to 500WHP as I can on ym PFab log with 5857 .83 v band backside..
Everything look okay? and any input on the regulator question would be appreciated!
Old Jun 18, 2011 | 04:51 PM
DFWs2k's Avatar
when i was looking into this route, the weldon fpr is what was suggested to me.
the aem should be a direct replacement though, so interested in seeing how it works for you.
Old Jun 18, 2011 | 04:52 PM
TurboCongo's Avatar
Only 1000cc injectors huh... im going with 1600 or 2000cc's.
Old Jun 18, 2011 | 05:09 PM
Spoolin's Avatar
1000cc injectors will be just fine for 500 whp on e85.
OP, I would say that there is a misprint on the AEM FPR. I used to run one of those and it did just fine up around 80 psi when I was at full boost.
Old Jun 18, 2011 | 05:37 PM
Suzuka_Joe's Avatar
Pfab elt would hit 500 pretty easily. On less boost too
Old Jun 18, 2011 | 06:30 PM
Fully aware but the log will too.. When I upgrade to an elt I'll be aiming at 8-900
Old Jun 18, 2011 | 06:33 PM
Deception's Avatar
Why so low?
Old Jun 18, 2011 | 06:35 PM
And thanks spoolin, I looked it up on other sites and it says 20psi- whatever the fuel pump can push
Old Jun 18, 2011 | 06:36 PM
Haha that's just the GOAL deception, we will see what the results are lmao, the goal for this build WAS 420 haha
staylor725
Dec 11, 2017 10:03 AM
ROFLv8
Jan 31, 2014 04:52 PM
Blucky87
Oct 13, 2011 08:16 AM
jbell
Nov 16, 2008 06:44 AM
slamar1
Sep 6, 2005 06:34 AM
