greddy turbo kit Ap1 vs Ap2
Old Jul 13, 2009 | 11:00 PM
lude9285's Avatar
Default greddy turbo kit Ap1 vs Ap2
Can an ap2 greddy kit be used on an Ap1? If so what changes need to be made? What are the differences between the kits?
thanks
Joel
Old Jul 13, 2009 | 11:07 PM
Randizzle88's Avatar
it will work the ECU harness might be different.
Old Jul 13, 2009 | 11:09 PM
jari8378's Avatar
thanks
Joel
look at the part numbers on the manual... the only difference that I see is the emanage harness
Old Jul 14, 2009 | 05:06 AM
RichV's Avatar
The harness AND the basemap on the EMU. Do not run an AP1 basemap on an AP2 or vice versa. Car will not run correctly!
Old Jul 14, 2009 | 06:05 AM
TRBOKEV's Avatar
Yep you got to unplug and re plug one wire, do a search its on here..
Also just reload the correct MAP.
Very simple to do.
Old Jul 14, 2009 | 07:54 AM
lude9285's Avatar
So the emanage is the only thing thats different....all the components of the kit are the same (injectors, fuel pump, etc.) ?
Old Jul 14, 2009 | 08:54 AM
Chris_Lum's Avatar
you have to be more specific:
00-03 ap1 and 04-05 ap2 are identical except for the emange pnp harness and basemap.
06+ kits have many different parts and are not recommended to try to be fitted to other models and vice versa due to the numerous changes.
Old Jul 14, 2009 | 09:26 AM
lude9285's Avatar
thanks....that's the info i was after
Old Jul 14, 2009 | 12:12 PM
Chris_Lum's Avatar
harness mods: https://www.s2ki.com/forums/index.php?showtopic=715212
k00leo
Nov 26, 2012 08:10 AM
durtbikedude365
Feb 24, 2011 06:17 AM
jimnasty23
Feb 16, 2011 07:53 AM
RichV
Aug 22, 2008 10:50 AM
