Greddy Turbo Kit And Engine Code Problem
Old Dec 20, 2009 | 07:39 PM
2006ap2's Avatar
Default Greddy Turbo Kit And Engine Code Problem
I Sorted Out The Issue I Had With The Gas Pedal Not Working At All, Now I Can Get It To Work But As Soon As Any Boost Comes Up The Throttle Stops Responding, It Throws The General Powertrain Engine Code And The VSA Light Comes On. I Delete The Code And It Works Like A Charm....Untill I Stab The Gas And Boost Moves Off Of Zero And Everything Turns Off Again...Anyone Have Any Clue What Is Up??
Old Dec 21, 2009 | 10:43 AM
psileepr's Avatar
Instead of just deleting the CEL you should pull the exact code and troubleshoot from there.
I would also double check all electrical connections you have done while installing the kit.
Old Dec 21, 2009 | 03:35 PM
crazysupratt's Avatar
what error code are you getting? is it MAP related error?
does it fall on its face on the upper gear like 3rd, 4th, etc...
Old Dec 22, 2009 | 07:27 PM
kira88's Avatar
im experiencing the same problem..
how fixes?
Old Dec 22, 2009 | 07:56 PM
2006ap2's Avatar
The problem has been fixed completly, the car runs great now!! It was the emanage harness, it wad wired fir the 04-05 ap2 cars, I brought it to them and they rewired it and it works great now, if you are having the same problem give greddy a call...
Old Dec 22, 2009 | 10:04 PM
jari8378's Avatar
^^ ha! I knew it.
Old Dec 23, 2009 | 03:19 AM
2006ap2's Avatar
^^Thanks Jari!!
Pitts2000
Jun 15, 2015 06:56 AM
dohcvtec661
Nov 26, 2013 09:48 AM
2006ap2
Jan 3, 2010 07:10 AM
Gfrnk69
Feb 8, 2009 02:15 PM
SpEeDxXxRaCeR
May 11, 2004 12:39 PM
