Greddy Turbo Kit and ID injectors.
Old Oct 16, 2011 | 02:03 AM
RedSunS2K's Avatar
Default Greddy Turbo Kit and ID injectors.
Bought the wrong injectors. They don't fit my car. Gonna return them and buy something else.
When the injectors are returned, I plan on picking up some ID 725 injectors w/ plug and play clips. My question is if this will work with the greddy turbo kit. All I need to do is, install them and have my EMU tuned correct? Do these require any modifications or do fit snug like oem injectors? Don't want to go through all the trouble and find out they don't fit again!
Old Oct 16, 2011 | 07:57 AM
DFWs2k's Avatar
just get ID1000s, aren't they the same price as 725s? they will idle like stock and will fit the stock fuel rail, 100%
Old Oct 16, 2011 | 08:26 AM
camuman's Avatar
They fit just fine. U will def need to be tuned.
Old Oct 16, 2011 | 10:55 PM
Kitesurfer s2000's Avatar
Whole new tune needed so get a greddy boost sensor to replace your map sensor for tuning over 10psi
Old Oct 17, 2011 | 06:52 AM
RedSunS2K's Avatar
I don't think I will be going over 10psi. Not yet anyways. Do I still need the greddy map sensor for these injectors to work?
Old Oct 17, 2011 | 07:10 AM
s2knoob89's Avatar
No, you don't need the map sensor.
Old Oct 20, 2011 | 05:47 PM
RedSunS2K's Avatar
I was reading some other threads and someone mentioned that the ID1000s are not very good with the Greddy EMU because it cannot be set for 1000cc. Is this true? I was also looking at the FIC 650cc Injectors. I only have goals of 300hp with the Greddy Turbo kit.
Old Oct 20, 2011 | 06:25 PM
DFWs2k's Avatar
You can set it as 999 and there is no difference
Sent using free Tapatalk - Android FTW
RedSunS2K
Oct 29, 2011 01:47 PM
lvd1102
Jan 18, 2010 11:21 AM
MySuzuka
Oct 18, 2008 12:01 PM
MySuzuka
Oct 5, 2008 06:43 AM
