Greddy Type S Adjustment
I have a type s on my greddy kit. I've done the single spring mod and only have the main hose connected. It's pretty much almost all the way backed out on the adjustment nut/screw. I'm getting compressor surge pretty much no matter what. Should I connect the other port to a vacuum source? It's starting to really get on my nerves.
get a different bov i see those things go bad all the time. i had 3 go bad on me on my old 240. they are complete junk. i tried rebuilding them the diaphragm gets wedged and holds the valve closed.
i personally love this valve. http://www.synapseengineering.com/
never any serge and supper fast response.
the bottom port is really just a breather for the other side of the diaphragm if you hook up the other side it can help push the diaphragm. Hook up a vacume t in between the compressor and waste gate acuator and hook that up to the lower part of bov. The constant pressure will keep the valve responsive. good luck hope this helped
having pressure on the other side of the diaphragm will help it be more responsive, but it should be work with just the top one. you could try this set up. http://herpetology.com/dsm/bov.html
take notice to the vacume lines
