Greddy Type S Adjustment
Old May 21, 2010 | 04:57 PM
itlynstalyn's Avatar
Default Greddy Type S Adjustment
I have a type s on my greddy kit. I've done the single spring mod and only have the main hose connected. It's pretty much almost all the way backed out on the adjustment nut/screw. I'm getting compressor surge pretty much no matter what. Should I connect the other port to a vacuum source? It's starting to really get on my nerves.
Old May 21, 2010 | 07:21 PM
SentTwoKill's Avatar
Get a different blow off valve, the greddy one sucks...
Old May 22, 2010 | 07:10 AM
AFs2k's Avatar
If you were to get one, get the Greddy type RS or RZ.
Old May 22, 2010 | 08:15 AM
freshs2k's Avatar
hmm i have the same BOV without issues. what single spring mod are you refering to?
Old May 22, 2010 | 08:28 AM
scors2's Avatar
get a different bov i see those things go bad all the time. i had 3 go bad on me on my old 240. they are complete junk. i tried rebuilding them the diaphragm gets wedged and holds the valve closed.
i personally love this valve. http://www.synapseengineering.com/
never any serge and supper fast response.
Old May 22, 2010 | 06:29 PM
LOL it's not really the alternative I want. I'm just wondering if I need to connect both ports instead of just one. The diaphragm is actually in really good condition.
Old May 23, 2010 | 05:44 AM
scors2's Avatar
the bottom port is really just a breather for the other side of the diaphragm if you hook up the other side it can help push the diaphragm. Hook up a vacume t in between the compressor and waste gate acuator and hook that up to the lower part of bov. The constant pressure will keep the valve responsive. good luck hope this helped
Old May 25, 2010 | 10:11 PM
Wait, so are you saying I should connect the other hose to help it open?
Old May 26, 2010 | 04:28 AM
scors2's Avatar
having pressure on the other side of the diaphragm will help it be more responsive, but it should be work with just the top one. you could try this set up. http://herpetology.com/dsm/bov.html
take notice to the vacume lines
Old May 26, 2010 | 05:30 AM
TRBOKEV's Avatar
Just buy a new valve, (turbosmart would be my choice since you can get it with the Greddy "type" flange)... Is $200 really worth boost leaks and/or compressor surge?
