GT35R Incredible!
I did, I never really paid much attention to the injector until I talked to Paul from Yaw Power. After I built that bench and tried a few injectors I realized how big of a difference they could make. I ended up using low impedance Bosch 1600's for their spray pattern and linear flow rate up to fairly high pressures. I have heard great things however about the new 1000cc injectors, I haven't got a hold of a set yet but I trust Paul's judgment he has a lot more experience with injectors than I do.
I did learn that published dead times are a complete joke, you might as well put random numbers in there.
the ID 1000's are no joke, they are better than any other injector i have ever used....hands down. i dont understand why people are still using anything else.
i seriously get frustrated when i use other injectors now when something comes in for a tuning appointment LOL it really is a night and day difference.
The biggest joke is all the people using resistor packs and low impedance injectors talk about a shitty band aid. The 1600 low impedance work great with a good peak an hold driver like the M800 has but put them on an AEM with a resistor pack and now you might as well have bought some machined crap right off ebay.
yea 1600's are pretty terrible. unfortunatly have not used a good ecu with a set (i have (8) 1000cc injectors with my m800). but going from a resistor box to a FJO driver is a whole new world.
im anxious to try out the ID 2000cc injectors. if they are half as good as the 1000's....they will be about 30x better than your standard 1600's lol
is your motec set up on a s2000?
Originally Posted by Momentum,Aug 14 2009, 06:30 AM
I'm not trying to hate, I think it's a great car and I'm sure your tuner knows what he's doing. The setup looks super clean. The numbers however are wrong, maybe he doesn't know it but they are. It's not even in the realm of possibility. I have as you brought up seen some of Mase's numbers that were higher than most likely possible as well and many that are about as expected I think that's a result of him tuning on so many different dyno's (how could he know what corrections are built into other peoples dyno's).
Joe, your example of how a 35r can make the big power comes from a dyno jet on STD correction which is not the standard and happens to be the highest of all the correction factors.
Do you really think there are "freak" fuel pumps that happen to flow almost 200 more horsepower on the same car? That's pretty much what your claiming since like you I see about 550 before issues on a dyno jet with a single walbro. The OP is claiming 650 on a dyno dynamics (720+) on a dynojet surely you don't believe this is possible with either the walbro or the 35R?
For reference:
https://www.s2ki.com/forums/index.php?showt...&#entry16750599
How could a car with a 4088R 1.19 housing, equal length tubular manifold, custom, intake manifold, no filter, 4 inch exhaust, no ac, and running on alcohol run the same boost pressure and make less power than a car with a 35R and a street setup on a dyno that reads about 12% lower.
You can say it's all in the tune but what are the chances that I have $10,000 in engine management computers, and $3000 in sensors and don't know how to use them at least up to par with the capability of an AEM. My car has over 50 hours of dyno time and every cylinder is tuned as it's own engine.
I usually know better than to say something in threads like this but every once in a while one comes up that is just way to far out there to pass up and I can't let it go. It's a bad habit but it's a pet peve and it eats at me when I see these threads hang around the top of the FI section. Then when truly honest tuners or people that make normal numbers post up they are ignored because they didn't do something "amazing"
The truth is unless you are truly clueless you will be within 10% (and even that would be pretty sad) of maximum power for your given setup when tuning WOT.
For reference:
made to date. Also going into an engine and building the engine to be most efficient for turbo application just increases ve.
As for the fuel pump I knew we were out but because we were running methanol injection and c16 fuel we were able to maintain a close enough fuel ratio to still be safe. The car went a little lean for my taste so we backed the car down to 24psi of boost.
Dynos are used for just #s and tuning. If we could some how make dyno to read brake specific fuel consumption and have the exact volumetric efficiency of the engine and it components we could simply figure exactly how much power the engine should produce. I hate all the d--k waivers out there that post about how much power they make. the real test is 1/4 mile or acceleration times post thoughs screw dyno #s to many dam bench racers in society now
The 4088 turbo sucks, scrap it and go with 4094 you will see much better results. the compressor map is horrible on the 4088 and I do think that it did come from some sort of diesel truck. The 4094 is what we run on are turbo kits for our nsxs the 4088 is great if you want to stay in the 500s anything more than that it sucks. you would be better off with the 35r or the new 37r that just came out have yet to use this one yet though. Nice setup with the Motec I wish I could do this for all of my customers. Nothing like being able to monitor everything I love it
Originally Posted by DYNOMIKE@AUTOWAVE,Aug 14 2009, 02:42 PM
It is true that all dynos do read differently a stock ap1 s2k will make roughly right around 200-205whp on my dyno. On thing you have to remember is that you have to look at the lbs per air using typical rule of thumb 10lbs of air per minute equates to a hundred hp I to thought this was maxing the turbo out and it was I origainlly thought the car would produce right at around 620 with the turbo maxed out but with the way I set this engine up I wanted to be able to make power well pass the 9500rpm mark. Proper degreeing of the camshafts will yield you this. If you push 60Lbs of air though an engine that only spins to 5000rpm you will have smaller peak #s. if you push 60Lbs of air at 10000rpm you will esentially have twice the amount of hp but less torque giving you that big peak # that is the case hear. this is not exactly true but just using it to try and get my point across. The higher the engine revs the bigger peak # you will make
Originally Posted by Asura,Aug 13 2009, 03:31 PM
Chris, let me know if you want a 3" resonated testpipe. It will kill a few dB for you.
REALLY nice numbers, for those of you that might have missed it, this is close to 780WHP on a Dynapack 4000...DAYUMM is all I can say. Nice job on the build Mike@Autowave
-Asura
-Asura
Since some people have questioned the overall capability of a "35R" turbo, I would like to mention that there are several Evos running a HTA35R and making over 600AWHP on a Mustang dyno. These numbers are further validated by consistently running low 9s in the 1320.
Assuming you can continue to fill the cylinders with the same volumetric efficiency (maybe what your getting at) you will make more power with rpm at an almost linear relationship. However since a 35R can only flow X amount of air you will not continue to make power with RPM in fact you will start to lose power even though you are still flowing the same about of air but loosing power at the top end of your pull because your efficiency is going down. By your theory you should be climbing at a linear rate until the rev limiter.
