GT35R Incredible!
Old Aug 15, 2009 | 10:27 AM
  #71
camuman's Avatar
if i had to guess, you will prolly hit 600-650 dynojet, and depending on how the dynapack is calibrated, 600-750 on it. thts what sucks about some dynos, when you can "calibrate" the numbers to read like other dynos in the area, you get tainted results.
i like the DD dyno, but even that one, you can put in a correction factor, and it wont show anywhere on the dyno that you did this.
no matter what, great numbers, and i look forward to your results on other dynos in the area.
Old Aug 15, 2009 | 10:29 AM
  #72
AndyFloyd's Avatar
Originally Posted by DeadZero,Aug 15 2009, 10:26 AM
im being optimistic hahaha. seriously we were all expecting a max of 625 on the dyno. we didn't know we were gonna make more then that.
but who knows... i just wanna try and see what we could do with it
Im down for you dynoing on all the different dynos. Would be neat to see what she puts down. Im just super impressed with your setup. It is a silver bullet. I bet when you hit 25psi it takes off like a rocket...my car on 480 felt pretty good...cant imagine trying to grab traction unless its 4th gear and up.
Old Aug 15, 2009 | 10:30 AM
  #73
2QYK4U's Avatar
Originally Posted by DeadZero,Aug 15 2009, 11:16 AM
i know!! isn't it awesome?!?! We hit an absolute record on how much this turbo can produce. stick around for dyno sheets from other dyno's maybe ill hit 750 on a dyno jet and over 800 on dyno pack!!! i've very excited for this potential
Yea and i do have a Walbro fuel pump, its at its limit tho during that one run
Road Race Engineering has a very respectable Dynapack that you could go dyno on. Here is a link to their site:
http://www.roadraceengineering.com/
You may want to dyno on a Mustang dyno as well while you are at it. Not aware of one in the LA area, but Reese Tuning in the Santee has one:
http://reesetuning.com/
Old Aug 15, 2009 | 10:36 AM
  #74
DeadZero's Avatar
[QUOTE=AndyFloyd,Aug 15 2009, 10:29 AM] Im down for you dynoing on all the different dynos. Would be neat to see what she puts down. Im just super impressed with your setup. It is a silver bullet. I bet when you hit 25psi it takes off like a rocket...my car on 480 felt pretty good...cant imagine trying to grab traction unless its 4th gear and up.
Old Aug 15, 2009 | 10:43 AM
  #75
2QYK4U's Avatar
Originally Posted by DeadZero,Aug 15 2009, 11:36 AM
you can't imagine it...i couldn't...
i kept burning out all the way to 6th gear... i havn't even expereienced the FULL pull of the 600+ horsepower run.
I hit it...spun out...80mph...hit it again spun out 95mph...hit it again spun out..110..hit it again spun out 115-120. it got too scary so i just gave up on trying to get traction on it.
I have very shi!!y tires that are almost bald too... i might have to buy a new differential if im gonna have sticky tires on to feel the full feeling of this car
DRs will be your best solution.
Old Aug 15, 2009 | 10:50 AM
  #76
camuman's Avatar
at the very least R comp tires. spinning 6th at 110 mph = scary.
Old Aug 15, 2009 | 10:59 AM
  #77
AndyFloyd's Avatar
i would hit it and it would spool for a second then tires would spin and so on and so on..
get some BFG 275's. that will keep those tires on the road. And for god sakes bald tires suck so bad for ANY traction.
Old Aug 15, 2009 | 11:21 AM
  #78
2QYK4U's Avatar
Hoosier is coming out with some new DRs:
http://forums.evolutionm.net/drag-racing/4...al-reality.html
As stated in that thread though, those are really for track use only. The BFGs you are referring to would be better suited for street use.
  #79
2QYK4U's Avatar
The new R888s might work out well.
Old Aug 15, 2009 | 12:14 PM
  #80
AndyFloyd's Avatar
was looking at those tires. they do look siiick
