Guages for a Turbo
Old Jan 4, 2006 | 12:30 PM
S2000_Europe's Avatar
Thumbs up Guages for a Turbo
I sold my guages and pilar pod, I will get some new, guages, my limit is 4 I do not want more. I was thinking in this one:
Oil pressure
Water Temp
A/F Ratio
Boost
Since I have a wideband with A/F ratio, I would have to relocated to a place where I can read it, i can avoid A/f Ratio gauges and use oil Temp, making the new combination
like this
Oil Pressure
Water Temp
Oil Temp
Boost
I do not know is oil temp is very important having the oil pressure which i think more important.
Any advise would be accepted
Juan
Old Jan 4, 2006 | 03:51 PM
Spankee's Avatar
I would do EGT before Oil temp.
Old Jan 4, 2006 | 04:01 PM
GPW03's Avatar
I would invest in a wide band setup, and avoid a standard narrow band A/F guage. Although the dancing light is nice your not getting a true reading of your A/F mixture. Below is what I would consider to be necessary on a boosted setup.
oil temp
boost
wide band (if you have this guage you won't need an EGT)
The water temp guage would be a nice addition but not necessary IMO. Definately consider the wide band as your first choice.
Goodluck!
Old Jan 4, 2006 | 05:26 PM
503s2k's Avatar
If you have the money, you should get a Wide Band, Boost, Oil gauge. But if you are short in cash then
4 most important gauges are
Boost gauge
EGT gauge
A/F ratio guage
Oil Pressure gauge
leave the Water and Oil temp out. Not as important as the those 4 above.
Old Jan 4, 2006 | 09:40 PM
Scorpion's Avatar
Boost gauge
EGT gauge
A/F ratio guage
Oil Pressure gauge
Old Jan 4, 2006 | 10:43 PM
pegi's Avatar
Sorry friend, but what is EGT--> exhaust gas temperature ???
I have:
Air/fuel ratio
oil pressure
Boost
Going to buy exhaust gas temperature.
There is my 4
Old Jan 4, 2006 | 10:54 PM
Scorpion's Avatar
Yup that's what it is. If you install one, I recommend the first runner in your exhaust manifold. That is the best place to get accurate readings from the cyclinders. I have seen it in the downpipe, but I personally feel that that gives the exhaust a little time to cool before getting metered.
Old Jan 4, 2006 | 11:59 PM
EGT and A/F does have the same funtion? watch how the mixture is? if your A/F ration is good your EGT should be the same
Old Jan 5, 2006 | 12:52 AM
Scorpion's Avatar
Not exactly. It's a common misconception. But you make a good point, if your AF is good than your EGT should be good right? Well what about timing? You can make a lean running car have good EGTs by retarding the timing. Like wise you can have a car that shows good EGTs but is running pig rich because of too much timing advance. That's why I recommend both AF and EGT. If you know you have good AF, then you can use the EGT to adjust timing.
Old Jan 5, 2006 | 08:28 AM
passmans2kny's Avatar
if your running the aem ems they just came out with a gauge that can read 19 differnt parameters, anything you want in one gauge, pretty sick, i think im gonna get 2, i dunno how much they run for but it will be worth it, www.aempower.com new hot sh1t
