Haltech map settings with Hondata 4 bar
Old Sep 12, 2013 | 06:07 AM
1SlowSi's Avatar
Default Haltech map settings with Hondata 4 bar
Does anyone have these settings you can share with me? I need settings where you input the voltage vs pressure table I.E -29 = 1v and 40 psi = 5v.
Thanks for any help gents.
Old Sep 12, 2013 | 06:20 AM
indi00's Avatar
Hondata 4 bar = Omni 4 bar based on the search function.
I'm using the Omni 4 bar settings for my Hondata 4 bar.
http://omnipowerusa.com/calibrations.doc
Old Sep 12, 2013 | 06:48 AM
CoolGuy094's Avatar
^That's what I used as well. I had this same post a few weeks ago: https://www.s2ki.com/s2000/topic/104...ar-map-sensor/
Old Sep 12, 2013 | 07:13 AM
1SlowSi's Avatar
I found that earlier for AEM but Haltech's is setup a little differently. I have a few settings that were inputted into KPro but that didn't exactly correlate to Haltech's table. The only thing I got from it was that 5v=46 psi and 1.17 was normal atmospheric pressure. Looking at the Omnipower document, it shows a table format but doesn't go below -14 for vacuum.
Old Sep 12, 2013 | 09:17 AM
CoolGuy094's Avatar
The Haltech software should interpolate on its own using the data that you input. Or you can interpolate on your own using Excel to determine what the linear formula is. Here is the linear formula for the 4 bar MAP sensor based on the table values from the word document:
(Volts) = 0.012106*(kPa)-0.042286
Old Sep 13, 2013 | 05:26 AM
sohc_mshue's Avatar
scalar = 838 mbar
offset = 31 mbar
pressure = 838*volts +31
Old Sep 13, 2013 | 05:42 AM
1SlowSi's Avatar
Originally Posted by sohc_mshue
scalar = 838 mbar
offset = 31 mbar
^ oh that's right I should have just called you lol. I'm going to send you the map Ive been prepping for the new setup.
Mr. Francesco
Jul 14, 2008 06:37 PM
tpc0531
Aug 20, 2006 04:06 AM
Honda-S2000VTec
Jan 25, 2004 10:59 PM
Legal Bill
Aug 18, 2003 10:57 AM
mfabry
Aug 30, 2001 08:21 AM
