Saner versus Gendron bar?
I have seen the Saner bar advertised under $200 while the Gendron bar goes for over $500. Has anyone compared the two? Is the Gendron worth the difference. For purposes of context, this is for autocross. I am currently on stock tires, but would like to go to Hoosiers next season and use the same bar.
Thanks.
Bill
Thanks.
Bill
Saner makes more sense to me. I think you'll have to make a trip to Home Depot to get the endlinks for the Gendron. The Saner bar is also priced reasonably. Get yours from the S2Ki Store.
http://marketplace.s2ki.com/s2ki/customer/...cf09a286b0105ca
It depends on what you're after. The Saner bar likely will be fine for most regional events (unless you happen to be in a region with national competitors). You're probably going to find it limiting in adjustment range as well as absolute stiffness by comparison but if you don't care, you saved a few $$$. If you're headed for Nationals, having to buy yet another bar will cost you $$$.
On an unrelated note, keep in mind that the Gendron bar's arms need to be machined down to clear aftermarket shocks with larger-than-stock bodies (e.g. Penske, Moton, JRZ). The new Saner bar allegedly clears aftermarket shock bodies, but I haven't seen anyone confirm that yet.
Steve
I am reluctant to even comment, but I think someone posted somewhere that the Saner bar is not as durable as the Gendron bar, or something. I recall it having something to do with the type of spring steel (or manufacturing process), and how it would weaken over time (torsion rates).
Now is that a rumor starter, or what?
BTW~ the stiffest position on the Saner bar was too stiff for Thunderhill and Laguna Seca as it induced a little more understeer than I wanted. I'm going to back it off to the intermediate setting hoping to regain a little of the rear end play.
Bill~ I contacted both Saner and Gendron before I bought and came to the conclusion that though the bars aren't identical, I saw no advantage of the Gendron bar that was worth $300+. Gendron likes to say that his bar has been used by champion autocrossers, but big deal... ask for the actual specs on #/in. of deflection (if that's the correct unit) of each setting of each bar and compare apples to apples. I'd give you that info now but I can't seem to find what I did with it.
Saners bar has been used by Auto-X champions too. Just not s2ks, but he has been making bars for all sorts of nationally competive auto-xers.
BTW Monkey: What size tires were you running? You mentioned after thill you found too much push for the track on full still, how come you didn't change it before laguna?
I should point out that full stiff is almost definately too stiff for the track. You need a lot less front sway bar for the track than you do for auto-x.
