Have problems using a 90 degree coupler with Pfab?
Originally Posted by siadam,Jun 11 2010, 12:00 PM
Whoring mine.
You should be able to just get a 90 deg aluminum elbow and use a coupler to hold it onto the turbo without having to weld it on. If you weld it on, it will degrade the turbo and not all people will have a manifold for that turbo that will need a welded 90 end on it if you ever wanted to sell it to upgrade. Also, Precision and other companies may not warranty that turbo if it has any problems and has been modified with a welded on 90 elbow.
I DIDN'T want to do this, but was forced to obviously. I'm thinking this winter, or maybe w/this setup depending on the motor I may go to a sidewinder.
Not sure yet.
Originally Posted by Ek_Jak,Jul 11 2010, 09:31 AM
hey do you have a problem with this since your turbo is resting on the frame? mine sits nearly just like that and i was wondering when the motor is trying to move during acceleration, would this stress out the manifold and turbo?
Originally Posted by Ek_Jak,Jun 11 2010, 03:18 PM
thanks for the pic! thought i was the only one that had such little room. where do you have your oil return line tapped? madjdm
