Headgasket blown?
Wow. So hold on, are you guys saying that a/m headstuds and gaskets are bad for our engines? My reason being is that I've just commited to purchasing this built motor that was built with the intention to turbo but was instead s/c'd:
The motor contains the following:
Block:
Laskey Racing Block
CP Pistons
Carrillo Rods
Darton Sleeves
ARP Headstuds
Brand New OEM Bearings
Micropolished crank
Head:
Ferrea Titanium Valves
Ferrea Titanium Dual Valve Springs
Ferrea Keepers
Ferrea Titanium Retainers
Port & Polished Head
Cometic Steel Head Gasket
Block:
Laskey Racing Block
CP Pistons
Carrillo Rods
Darton Sleeves
ARP Headstuds
Micropolished crank
Head:
Ferrea Keepers
Did a compression test
Cylinder 1,2,3 all 15OPsi
Cylinder 4 125psi
Pulled the head and inspected the gasket etc. ARP's were properly torqued. HG looks fine. There are a few things I noticed.
Intake valves on #4 noticeably shinier black then others.
Block guard somewhat clogged from coolant.
Dark black/green oil.
Here's a few pics just to get any and all advice.
Improper bore size?
Broken rings?
Cylinder 4 125psi
Improper bore size?
Broken rings?
It's not exactly 2mm anymore.2 layers were removed so I'm guessing 1.40 give or take.
Any suggestions guys? I just naught telescopic gauges and a caliper gauge to measure bores up.
Sent from my DROIDX using Tapatalk
