HeadGasket or Built?
Old Nov 19, 2007 | 07:26 PM
ChefJ's Avatar
New headbolts sretch and are supposed to be retorqued after one heat cycle. Which I feel is absolutely stupid to go through all of that labor and time to warm the car up for 5 minutes and then disassemble it all to retorque.
But that is what is supposed to be done.
I reused my original bolts which were already stretched to the max.
Old Nov 19, 2007 | 07:39 PM
brainwo's Avatar
Re-torque is not require after heat cycle with stock head bolts, new or re-use.
I found best lube to go with is ARP Molylube, even with stock head bolts.
Old Nov 19, 2007 | 07:50 PM
AirborneS2K's Avatar
I have 450whp on my GT3076R and love it. I can easily hit over 500whp with a race gas tune on this setup; I just never run race gas b/c its a pita to order and expensive as hell. Do I want more? eh, I could if I wanted to, but I rarely use all 450whp and 330wtq around town, so I sure as hell don't need it. I'm content with 450whp. 600whp for a street s2k is just stupid imo.
Old Nov 20, 2007 | 05:00 AM
PeanutButter's Avatar
I figured tha is what happened. but was told it was uneccessary
Old Nov 20, 2007 | 05:38 AM
S2KPANG's Avatar
Headgasket if you're on a budget.
I've never had to retorque head bolts/studs after a heat cycle, not necessary if done right the first time. Never have had a problem. I mean dealerships don't do that on brand new cars...
Old Nov 20, 2007 | 06:03 AM
camuman's Avatar
after seeing what can be done on a stock block no 3mm hg, 400whp, why worry building the block for 450whp? with a hg 3mm, you lower the compression to something in the low 9.X:1. as long as its assembled properly and tuned well you'll be fine. now, if you want 500whp+, then your in the game for the long haul, building the block is just one of the many expensive things you will be buying
Old Nov 20, 2007 | 07:38 AM
b/c 400whp isn't enough, 450whp is better. oh noes, not 9:1 compression, god forbid you make more power on a lower compression with a TURBO of all things.
Old Nov 20, 2007 | 08:43 AM
Spoolin's Avatar
Originally Posted by PeanutButter,Nov 19 2007, 08:32 PM
I went with the IP 3mm headgasket.
2 weeks later it warped, so now I am doing it the right way.
That sounds like an install problem and/or bad tune that would have caused that.
Old Nov 20, 2007 | 08:47 AM
Spoolin's Avatar
Originally Posted by PeanutButter,Nov 19 2007, 09:13 PM
Probably not....
Brand new OEM headstuds were used, along with a factory manual, a 10 year Honda mechanic, a 10 year Honda enthusiast, and verbal help from Ya and another big name in the Honda world.
Ok, maybe a bad tune then.
I had a professional torque the head for me but I went with ARP headstuds and haven't had one problem. I'd say it stretched the headbolts and the heat warped it. I would never recommend using headbolts unless you plan on staying under 15 psi. They are a stretch to seat type of retainer unlike a headstud.
Old Nov 21, 2007 | 07:47 AM
camuman's Avatar
i think i didnt explain what i meant well enough. i reread it and it is confusing.
400whp = no headgasket with good tune
450-500whp = hg 3mm and good tune. <i like lowering the compression, if its needed>
500whp++ = build the biatch for longevity.
this is just my opinions.
i built my h22 with 9:1, i would have gone wiseco 8.5:1 if they were in stock. i love lower compression, leaves the window for fubar larger, though i still found that ****in window twice they say if your breaking stuff your going fast....but still was pain in the ass. two huge thumbs down for fmu/msd boostretard/vafc tuning. i wish i had bought an aem from the start. when i boost this car, aem with built in wideband all the way.
not too mention a full point of compression is like sacraficing 10whpish. big deal, turn the boost up to compensate.
JSanford2032
Apr 8, 2019 04:40 AM
ap1ap2whocares
Oct 21, 2012 12:01 PM
DFWs2k
Oct 22, 2011 10:50 AM
VashRacing
Mar 5, 2007 06:44 AM
