HEADGASKET is Fine, jumped the gun without
Old Jul 12, 2010 | 06:13 AM
  #121
JoeyBalls's Avatar
[QUOTE=TRBOKEV,Jul 12 2010, 05:23 AM] Joey, you still should run a leakdown test to determine if the head gasket is OK, if you haven't already had it done this past weekend.
Old Jul 12, 2010 | 06:33 AM
  #122
TRBOKEV's Avatar
Originally Posted by JoeyBalls,Jul 12 2010, 06:13 AM
did u run a compression test before hand?
I should have done one, I was pressed for time. Does your car overheat in boost?
I didn't run a compression test, it's honestly completely useless unless you have a catastrophic failure of the gasket or motor. You need to do the leakdown and more importantly keep pressure in the cylinders with the radiator car off to check for rising coolant in the radiator.
My car has NEVER overheated or even gotten hot for that matter.
I have had heat all but one time and all it took was one blip of the throttle that one time and the heat was instantly back at full strength for good.
Old Jul 12, 2010 | 07:02 AM
  #123
JoeyBalls's Avatar
damn, thats not what I was hoping to hear. I am keeping a close eye on the overflow tank, I will get a leakdown done when I can, I should have just done it there
Old Jul 12, 2010 | 07:06 AM
  #124
TRBOKEV's Avatar
Yep.. Be sure when they do the leakdown to keep each cylinder compressed for at least one minute with the radiator cap off. I can not stress this enough, as your numbers can still be fine but it will still push coolant which means bad gasket.
I dont mean to scare you Joey, I just want you to get a for sure answer.
I honestly think a lot of people have this issue, they just don't test properly for it to diagnose.
Old Jul 12, 2010 | 07:07 AM
  #125
JoeyBalls's Avatar
Yea, Minitoyota has done 100s of headgaskets, I will bring it to hi to run a leakdown test, just to be sure
cjts2000
Nov 28, 2017 10:49 AM
DogBiscuit
May 28, 2015 10:50 AM
Millenion LTD
Feb 14, 2008 03:47 PM
Jasonoff
Apr 18, 2006 08:22 AM
