Headstud/bolts
Old Dec 15, 2006 | 08:44 AM
S2KB00ST's Avatar
Default Headstud/bolts
I'm planning to do the gasket for boost but is it advisable to also change the oem for ARP or the like headstuds/bolts?
Old Dec 15, 2006 | 08:51 AM
Scorpion's Avatar
I've seen good luck with both. My car has a 2mm using stock and I'm safely running 17psi. A buddy of mine has a 3mm using ARP studs and we have him at 21psi no problems. Sorry I can't say which is better.
Old Dec 15, 2006 | 09:03 AM
S2KB00ST's Avatar
Did you just reuse the oem or new oem?
Old Dec 15, 2006 | 09:20 AM
Scorpion's Avatar
reused the old ones, just follow the manual when you are tightening them.
Old Dec 15, 2006 | 09:45 AM
Black Nugget's Avatar
I am using a set of ARP Head Studs from Atomic Speedware.
http://www.atomicspeedware.com/medianewproducts.htm
The third product on their are the S2000 Head Studs! To date, no problems!
Old Dec 15, 2006 | 09:52 AM
John_Z's Avatar
If you reuse your old head bolts make sure you check for stretch per Helms.
Old Dec 15, 2006 | 06:30 PM
gt30r's Avatar
You can purchase a set from Laskey
Old Dec 15, 2006 | 07:22 PM
ideugene's Avatar
I got mine from Raceware out in Michigan. More money than ARP but they've help up great.
rrounds
Jun 28, 2018 09:12 AM
donaldmejr
Sep 30, 2014 05:38 AM
JuicedS2K
Jun 1, 2010 07:29 PM
ChefJ
Apr 14, 2010 07:21 AM
afwfjustin
Mar 27, 2007 07:37 PM
