arp studs or oem bolts for built motor?
Old Apr 13, 2010 | 01:04 PM
ChefJ's Avatar
Default arp studs or oem bolts for built motor?
I have the full set of oem bolts still, but am curious if I should just spend the 130ish dollars on arp's.
The block is out at laskey getting the full 9:1 job and the head has been built for about a year now waiting to get the block finished. I am obviously going with a stock sized HG so should I just go with the arp's or stick with the used oem bolts??
Old Apr 13, 2010 | 01:22 PM
Spoolin's Avatar
Definitely ARP studs and I'm sure Mike Laskey will tell you the same.
Old Apr 13, 2010 | 10:09 PM
S2000_FUN's Avatar
Old Apr 13, 2010 | 10:34 PM
godmachine's Avatar
I thought that people had issues with the ARP ? I went new oem with no issues so far
Old Apr 13, 2010 | 11:08 PM
Spoolin's Avatar
Not if they are torqued correctly in 3 steps, to the correct final torque and with the supplied ARP molylube. They wont stretch like the OEM bolts will under big boost, possibly lifting the head.
Old Apr 13, 2010 | 11:20 PM
godmachine's Avatar
Ah maybe I will switch over to them
Old Apr 14, 2010 | 06:02 AM
siadam's Avatar
I'd think if you have the motor apart, swap the bolts.
On a stock motor, I wouldn't worry about it.
Old Apr 14, 2010 | 07:19 AM
Irishflame27's Avatar
ROB! made 772whp on stock head bolts.....
Old Apr 14, 2010 | 07:21 AM
killabee's Avatar
I talked to the builder @ inlinepro and he suggested arp.
05TurboS2k
Apr 30, 2012 08:52 AM
brendanj85
Nov 23, 2011 02:00 AM
RedLineS2k10
Mar 21, 2010 10:49 PM
afwfjustin
Mar 27, 2007 07:37 PM
S2KB00ST
Dec 15, 2006 07:22 PM
