Heat Shielding Use with PTuning Turbo Kit?
Old May 1, 2012 | 11:12 AM
indi00's Avatar
100's of WOT third gear pull here. No heat issues with the Ptuning kit with stock lines. Turbo sits low. The heat shield that comes with the kit is too bling though. Just personal preference...
Old May 1, 2012 | 11:13 AM
sata3000's Avatar
I also have no aftermarket heat wrap on my kit. But if I did it again I would at least get a turbo blanket
Sent from my SPH-D710 using Tapatalk 2
Old May 1, 2012 | 02:43 PM
EternalLx's Avatar
I too have no extra heat protection other than the provided metal heat shield. 1.5 years and I think 15,000 miles on the kit and nothing even looks a bit toasty. Ran the car though 7 20min road course sessions too
Old May 2, 2012 | 06:12 AM
dsddcd's Avatar
Originally Posted by 05TurboS2k
BEFORE you wrap a manifold or downpipe, get it ceramic coated, then it won't rust and it'll also keep the heat INSIDE the pipe rather than heating the pipe causing cracks and wasting energy. Do your hotside of the turbo as well. Faster spool, more hp, less heat, less cracking, wins all over the place!
No nessacary Ptunning use stainless pipe a flanges even the turbine housing is stainless, it won't ever rust! Ceramic coating in my experience is a waist unless as you mentioned the parts are steel.
Old May 3, 2012 | 10:14 AM
BaRHooM's Avatar
what about the DEI heat shields ?
Old May 3, 2012 | 04:46 PM
Forcedbird's Avatar
Thanks for all of the input especially MisMyS and s2000442 for answering my e-mails and PM's
ATP is hi quality stuff and I wish I could get it, but hi quality stuff comes with very high prices and I have to set a limit as with how much I want to spend on the project (for now!!!! )
I have been looking into the PTP turbo Blankets.
http://www.ptpturboblankets.com/t4.shtml
Any reviews thoughts or input.
For the manifold I am just going to stick with the PTuning heat shield for now.
Thanks
Old May 3, 2012 | 05:50 PM
s2knoob89's Avatar
I have the ptp blanket and it's works pretty good. After a long drive I can pop the hood and put my hand directly on the blanket and not get burned.
Old May 3, 2012 | 06:04 PM
s2000442's Avatar
Thanks
No problem man. I get it about the money, in the end it's your choice. At least your doing something.
Old May 11, 2012 | 07:09 PM
mr-pitts's Avatar
I made my own out of 1.5mm 10x20 inch aluminium
Old May 11, 2012 | 07:13 PM
Forcedbird's Avatar
Nice, looks great. How did you make that?
