Heat Shielding Use with PTuning Turbo Kit?
Old May 11, 2012 | 07:22 PM
  #21
mr-pitts's Avatar
You have to remember its a RHD car,but I used a piece of card as a template to get the holes in the right place,I had 2 pieces of aluminum cut 10x20 and 12x24 the 10x 20 was the best fit.once that was decided it was just a case of gently bending it around my leg to get the best/closest radius.I also radiused the corners for a neater finish and finished the edging with 3 mm id vacuum hose.Ill pos up a couple of pics of the heat reflective sheet I fitted aswell.I sprayed the cool side with VHT wrinkle finish. Hope that helps
Old May 11, 2012 | 07:24 PM
  #22
mr-pitts's Avatar
Old May 12, 2012 | 02:48 AM
  #23
Forcedbird's Avatar
Looks like a stock piece, very professional.
Thanks for the info!
Old Jul 24, 2014 | 10:51 AM
  #24
4forall's Avatar
Damn i really like that one! I have already burnt up my A/C lines. Hoping the member on here can get the relocation kits started up again. I really want a heat shield like that for my own setup.
ino20
Mar 12, 2020 01:01 PM
BrockB
Feb 13, 2013 04:01 PM
OneQuickS2K
May 5, 2003 10:26 PM
Ben
Jun 26, 2001 03:59 PM
