help advice plz!
Old May 10, 2012 | 11:05 AM
bois2k's Avatar
Default help advice plz!
hey guys a week ago before i left on my vacation i was leaving work started my car and noticed the oil light came on car sounded good tho but i turned it off and towed it home so i could see what the problem was without causing any damage to the motor,, i dont have a oil pressure gauge so i had to install one just to make sure i was alright and i do have oil pressure it was at 75psi cold start so i replaced the oil pressure sensor and the light is still on what could it be? car sounds good but still dont want to drive it that red oil light still scares the s**t out of me ha,, any help will be appreciated
01 f20c turbo aem series 1 inline pro kit
Old May 10, 2012 | 11:09 AM
herecomesboost's Avatar
Any melted wiring?
Old May 10, 2012 | 11:18 AM
sohc_mshue's Avatar
If your oil pressure is registering 75psi on the gauge then what are you worrying about? Find out what is wrong with the oil pressure switch and fix it.
Old May 10, 2012 | 11:21 AM
S2K-F8's Avatar
Not sure how long you've been turbo so.....Oil filter relocation kit hooked up backwards? (if you had to relocate it)
Old May 10, 2012 | 11:30 AM
bois2k's Avatar
Well I replaced the oil pressure sensor the wire was pretty beat up so I replaced what wad bad and the oil lines from the relocation kit are good haven't messed with them :/ thinking about just replacing the sensor with a gauge but I'm sure the aem needs it
Old May 10, 2012 | 12:06 PM
GoOn3's Avatar
Wait a second.... Your car has an AEM ECU and you got an oil light?
Old May 10, 2012 | 12:14 PM
bois2k's Avatar
Yes I have aem series one and recently got a oil light
Old May 10, 2012 | 12:34 PM
GoOn3's Avatar
Maybe I am wrong but it was my understanding that when you go AEM (series 1 or 2) that the oil light and check engine light dont work.... I guess I am wrong on the oil pressure sensor. It sounds to me that it is a faulty switch.
Old May 10, 2012 | 01:34 PM
TerminatioN's Avatar
This is a common misconception. The oil light will still work (although you are correct, the CEL does not).
I know this for 100% sure because awhile back one of the oil lines on my relocation kit split and blew off and spewed oil everywhere to the point where the engine was VERY low on oil. Low and behold my oil light came on. Very glad it did, otherwise I might not have noticed in time.
I'm using the AEM 1052U EMS, btw.
Old May 10, 2012 | 06:38 PM
kyle1981's Avatar
Banned
Originally Posted by TerminatioN
This is a common misconception. The oil light will still work (although you are correct, the CEL does not).I know this for 100% sure because awhile back one of the oil lines on my relocation kit split and blew off and spewed oil everywhere to the point where the engine was VERY low on oil. Low and behold my oil light came on. Very glad it did, otherwise I might not have noticed in time.I'm using the AEM 1052U EMS, btw.
Also not true on arm v2. I have two s2000s both running aem v2 and both oil pressure sensors are removed this being wear I draw oil for my feed line. I have been running one since august 2011 the other since around December 2011. Neither have ever thrown a oil sensor light. Maybe it's different in the aem systems. As far as v2 u can disconnect the oil pressure sensor and you will not get a light. Could u possibly have a grounded wire to that light?
