help advice plz!
Old May 11, 2012 | 09:29 PM
  #21
05TurboS2k's Avatar
Lot of interesting opinions in here on the subject.
1052 user here, oil light works fine, I've removed the oil pressure sensor some time ago.
Old May 11, 2012 | 09:30 PM
  #22
05TurboS2k's Avatar
Originally Posted by GoOn3
Just to reiterate what you'll are saying.... I looked at the wiring schematic and the oil sensor is directly connected to the gauge cluster and never goes to the ECU. That means no matter the version of AEM or Hondata or Haltech etc that you use, you will still have oil dummy light functionality. I think, like in the case of Termination, it is a nice safe guard to have. Due to my turbo set-ups I have had to use an oil relocation kit so thats where i get my feed/ oil pressure from.
I like your thinking.
Also on the subject of the light as a safeguard, I would like the option to cut power partially or fully when low oil pressure is sensed. I mean when in the world would you want to run the motor with low oil pressure, it means instant destruction. I'd much like it to throw a switch and demand me to over-ride it to continue driving the vehicle.
Old May 11, 2012 | 10:13 PM
  #23
Deception's Avatar
Originally Posted by bois2k
Well when I removed the sensor and installed the gauge the light went way so was thinking I should just buy the gauge and replace the oil pressure sensor would that be ok or do I have to have it ??!!
you dont need the stock oil sensor with AEM or stock ECU
Old May 12, 2012 | 05:31 AM
  #24
spectacle's Avatar
Originally Posted by o'malley_808
The sensor is a switched ground meaning you have to touch the wire to a grounded point on the chassis for the light to come on.
Just disconnecting the wire will not give you a oil light in the dash, you must touch it to the chassis.
This is correct.
liquidgsr
Jul 2, 2016 05:06 AM
vduber
Oct 9, 2012 08:54 PM
vaamntxoovzeb
Aug 24, 2010 09:18 AM
skool u
Apr 15, 2009 06:56 AM
P'sS2k
Apr 12, 2008 10:32 PM
