HELP CEL!, whats next?
Old Nov 6, 2008 | 08:43 AM
  #31
RichV's Avatar
Man.... you seem to have bad luck with your car!! Hate to hear that bud. Hopefully you will get it straightened out.
Old Nov 6, 2008 | 08:44 AM
  #32
JoeyBalls's Avatar
Im going to, I dunno it is one of three things
Failed TP sensor <----need a new TB
Throttle body malfunction <-----need a new TB
Open or short circuit condition <-----dunno what I would need then
The scanner said "Throttle position higher then expected", I don't know what that means other then the fact it does idle around 1300 to 1400RPM
Old Nov 6, 2008 | 08:55 AM
  #33
Soul Coughing's Avatar
do you have any vacuum leaks? one of the guys on here had a DIY to remove the throttle position sensor and put a new one in. You didnt need to replace the whole TB. ALthough the go for pretty cheap on ebay.
Old Nov 6, 2008 | 08:58 AM
  #34
JoeyBalls's Avatar
hmmmmm I might have a vacuum leak, I mean I checked all lines but I will check again when I replaced my manifold a few days ago I may have done something half-assed or so I dunno. If a whole TB goes for cheap on Ebay I may do that, what a scam that you just can't buy the sensor.........
All this headache for 300HP, WTF, I mean for all the headaches I have you would think I would be butting down at least 400.......
Old Nov 6, 2008 | 09:00 AM
  #35
SgtB's Avatar
Probably a vac leak. Also give the emu wires a good push and make sure everything is still in good contact.
Old Nov 6, 2008 | 09:10 AM
  #36
JoeyBalls's Avatar
Roger, thanks
Old Nov 6, 2008 | 09:23 AM
  #37
Revenge's Avatar
Why don't you take it to Ptunning or James at Jeimports and have them fix it for you? I know James has a bunch of engines around he may have a used part.
Old Nov 6, 2008 | 09:25 AM
  #38
JoeyBalls's Avatar
I am going to P-Tuning November for them throw on the Greddy MAP, as well as re-tune my car using METH (shooting for 12PSI), would like to be around 330RWHP
Old Nov 6, 2008 | 09:29 AM
  #39
ChefJ's Avatar
its cheaper to go with an aftermarket TB and sensor then to purchase the OEM piece.
Old Nov 6, 2008 | 09:34 AM
  #40
JoeyBalls's Avatar
who makes em?
