help with comptech sc install
Old May 9, 2008 | 11:08 PM
ECU Pirate's Avatar
Default help with comptech sc install
I am in the middle of installing the used comptech aftercooled supercharger I bought recently and I need some advice.
The instructions I received are very incomplete, and do not cover the installation of the blower, icebox, FPR, vtec side mount, and other miscellaneous items. Does anyone have a complete set of instructions in electronic format? I have found a couple of helpful points in searching s2ki, s2kca, honda-tech, and a few other places, but not enough details. Also, there is a small metal blue plate with a banjo bolt and a oil outlet. It looks like it should mount below the side vtec blower mount. Is that where it goes? Is it supposed to have a o-ring with it? Mine is missing if so.
Any advice is appreciated!
Old May 9, 2008 | 11:17 PM
scott2055's Avatar
PM-ed
Old May 9, 2008 | 11:54 PM
ECU Pirate's Avatar
Thanks scott for the instructions in PDF.
Here is a picture of the metal piece that I have no idea what it is:
And does this pic of the sc pulley look correct? It has a thick metal disc at the base, then the woodruff key with the pulley, then I put in a little brass fitting with a rubber mount, and on top is the bolt with a sort of metal washer:
Old May 9, 2008 | 11:56 PM
ECU Pirate's Avatar
Never mind on the first pic...I just found it under the instructions for the FPR....thanks
Old May 12, 2008 | 02:14 AM
ECU Pirate's Avatar
Scott, thank you very much for providing me with the instructions. The ones you provided were for the non aftercooled kit, but I had that section, which was provided with the kit...
THE INSTALL IS FINISHED. Yay! It runs, but is still on jack stands. I will be re-installing fascia and other misc items Monday.
Old May 12, 2008 | 05:58 AM
scott2055's Avatar
Anytime, have fun with the SC!
Make sure you soldered those ESM connections really well before you put all the trim back on!
Old May 12, 2008 | 11:23 AM
ECU Pirate's Avatar
I soldered, heat shrink wrapped them. and electrical taped the two that I couldn't heat shrink wrap.
Old May 13, 2008 | 09:06 AM
ECU Pirate's Avatar
btw, dyno'ed last night on a mustang dyno. The baseline dyno was 192whp bone stock, and is now 267whp with the aftercooled sc!
Old May 13, 2008 | 02:11 PM
s2000Junky's Avatar
How much psi did the kit make for you? and what AFR? Was the belt slipping at all do you think? Seems a little low. Shouldn't it be closer to 290 stock? I guess the Mustang Dyno reads a little lower then a dyno jet, but not by 25whp.
Old May 13, 2008 | 08:34 PM
ECU Pirate's Avatar
was making 4.5psi of boost according to the readout. AFR read good until vtec engagement, where it was consistently at 13.2:1 for just a moment. I think I have a boost leak because the sc to aftercooler couplings are too small. Will be replacing them with slightly longer couplings.
