Help with CT vacuum hose connections
Old Aug 5, 2006 | 10:46 PM
elusiv's Avatar
Default Help with CT vacuum hose connections
I'm running a 2002 Comptech SC with aftercooler.
Can anyone help me identify where A and B connect to? Kit is second hand, so I may be missing hoses... and the instructions on the comptech website are a bit difficult to understand.
thanks in advance.
Old Aug 6, 2006 | 01:02 AM
markS2kcU's Avatar
Have you got the Comptech aftercooler?
If you have they connect to that.
Comptech aftercooler fitting instructions.
Old Aug 6, 2006 | 07:03 AM
icemans2k02's Avatar
not sure what A is, but B will not connect to anything, just go to autozone and find a filter element to stick over it as it is still sucking air. Is A your BOV..if so just run a hose from that to one of your vacuum hose back to where your FMU is.
Old Aug 6, 2006 | 07:52 AM
elusiv's Avatar
yes, i have the aftercooler also.
the aftercooler has 3 openings on it. 2 are used for the coolant to flow in and out, and the 3rd opening is for B... but im not absolutely sure
Where does A connect to?
Old Aug 6, 2006 | 08:08 AM
elusiv's Avatar
does A just get plugged up?
Old Aug 6, 2006 | 08:59 AM
markS2kcU's Avatar
"A" gets plugged if your running a BOV on the comptech cooler.
If not it goes here on the comptech cooler.
"B" goes here.
Clear as mud now?
Old Aug 6, 2006 | 09:46 AM
i see the aftercooler on the comptech is different then vortech
Old Aug 6, 2006 | 10:31 AM
elusiv's Avatar
yes, im running a godzilla bov.
awesome! i'll go find somethign to plug it. thanks a ton mark!
Old Aug 6, 2006 | 11:40 AM
cpoz's Avatar
If your running a Godzilla BOV, you don't need to connect anything to "A". You just need to connect a vacuum source to the connection on the Godzilla BOV.
Dat956Boi
Oct 26, 2014 11:09 PM
lude92_si
Jul 16, 2013 02:59 PM
Dizings2k
Dec 23, 2005 10:50 AM
ayS
Dec 2, 2005 07:07 AM
EriS2k
Sep 4, 2004 10:12 AM
