Help with iat temps
AJ just fyi, if you have any doubts about the pump in the future, you can remove the fill cap on the A/C and see the water circulate, there will be a good constant movement. My pump is set to come on with the acc ignition so i can hear the pump and water movement in the A/C with the engine off.
Confirmed it was the pump, the new one is so much smaller.
Iat drops below 45c and then hover around this, when in boost the temps drop like a stone
this is good because the stock ECU pulls timing if the IAT report temps of over 45c in WOT.
