Help! Lost the cap to my Aftercooler
Old Aug 11, 2009 | 03:40 AM
tjbubb's Avatar
Default Help! Lost the cap to my Aftercooler
So i got home and lifted up the hood on the s2000 and realized that i was missing the cap that screws onto the top the the Vortech aftercooler!
1) what does this cap do?
2) where can i find another?
Thanks
Old Aug 11, 2009 | 05:34 AM
s2000isu's Avatar
Hahaha I did that once. It ended up getting stuck in my engine compartment and fell out while I was driving somehow I heard it bounce up hit the bottom of the car so I turned around and it wasnt even damaged. Anyways its to filly the aftercooler I guess you didnt install and dont check your fluid? You can just order them from vortech.
Old Aug 11, 2009 | 05:43 AM
tjbubb's Avatar
so it is used to fill the aftercooler with fluid? should i not be driving around with it like this?
Thanks
Old Aug 11, 2009 | 05:56 AM
s2000isu's Avatar
well if you lose all of your fluid you will burn your pump up. I would remove the fuse from the pump so it doesnt run anymore. As long as the pump is turned off its fine to drive with no fluid in there.
Old Aug 11, 2009 | 07:18 AM
tjbubb's Avatar
thanks
JawKnee
Jun 11, 2011 09:51 PM
JoeyBalls
Jul 7, 2010 06:22 AM
muffin7
Oct 3, 2007 06:37 PM
trivium
Nov 22, 2006 03:36 PM
joes sled 2000
Jan 12, 2005 06:10 PM
