help me pick a turbo!
Hey guys in the middle of putting my Turbo kit together and I'm looking for advice for a different Turbo. My goal was 600+ on E85. I currently have a bw S256. From my research this wont get me much over 500whp. I'm looking for something that's going to have a good spool with strong mid. Its a street car that does see the drag strip.
I'm running a pfab elm so it has to be T3. I was looking at maybe a S300 Turbo but not sure on spool or fit. Any advice will help would like to keep it in the 1400 or lower price range.
Thanks
Thanks
My last turbo, a Turbonetics Hurricane 6665 did a great job and worked perfect on the F20. 600whp easy and if you can afford ball bearing you´ll have better spool than I had on journal bearing. Made max power at 9500rpm.
Another cool turbo is the Garrett GTX3076, should max out around 600whp on E85 with great spool. Maybe a bit expensive?
What a coincidence. I'm in the same boat as you. Switching from a comptech N1000 making 355whp to a Pfab ELT T4 turbo set up. I'm going to be running a Precision 6165BB turbo with .81a/r on the hot side. Running E85 hoping to make 500whp on ID1000 injectors.
Kangaroo I'm also coming from a novi1000 that I made 405whp. To this pfab setup. At 1st I was just going for 500whp but since I'm switching to e85 I said hell I'm spending the money I want 600whp. That should be more than enough for the street and still beat up some of the V8s at the strip.
