help with s/c install problems
we installed a v2 vortech s/c on an 04. On the test drive the a/f ratio's were screwy. Anywhere under full boost the a/f bounced erratically from rich to lean back to rich and so forth. Around 5% throttle (guestimate) it was consistently rich. Under full boost it ran real lean and the car pulled timing and it felt like there was hesitation.
Another problem that may or may not be related is that full boost showed up as only 3 to 4 psi on the boost guage. Autometer phantom mechanical btw. I know its not the most accurate but the car def wasnt pulling like other s/c'd s2ks.
fmu was done by the black box.
any suggestions. thanks in advance
Originally Posted by jojipoji,Feb 7 2010, 09:43 PM
we wired it up with the vortech kit. the ignition control box from vortech. i know its crap but the car is stock otherwise. any suggestions?
