help... turbo moving
Old Oct 12, 2013 | 03:54 PM
wildkart's Avatar
Default help... turbo moving
I am running the fullrace ramhorn manifold and precision 6266.. I can take the intake pipe and move it and there is play in the center chunk of the turbo between the hot and cold side..
Any ideas why and how to fix?
Old Oct 12, 2013 | 05:37 PM
d-bo's Avatar
are you talking about shaft play? It is ok to have a little and not really a big deal. mine has a bit and is fine. as long as there is no blade damage, or it isn't smoking the turbo is more than likely ok.
if it gets to that point you can send it out and have it rebuilt. if it's a ball bearing unit you can just buy a new one and make a cool lamp out of your old one
Old Oct 12, 2013 | 08:21 PM
neeman77's Avatar
Are the bolts for the compressor housing/turbine housing tight?
Old Oct 13, 2013 | 05:59 AM
wildkart's Avatar
No not shaft play.. its the center chunk the moves a little back and forth.. I noticed it when cleaning my intake pipe for a show, the hole thing moved a little back and forth.. and yes I just tightened all the turbine housing bolts..
Old Oct 13, 2013 | 06:11 AM
bobbyrandolph440's Avatar
So it's like it's not flush on the flange against the manifold?
Sent from my VS870 4G using Tapatalk 2
Old Oct 14, 2013 | 08:08 AM
passmans2kny's Avatar
i would take it off and get a better look at it, that doesnt sound right
Old Oct 14, 2013 | 10:07 AM
wildkart's Avatar
Yeah, I figured out it seems the be the 6 bolts on the hot side have loosened up a little bit. I will be taking it all apart thursday on my day off. I can't get to the bolts with it on since i run the turbo blanket..
Thanks guys.
Old Oct 14, 2013 | 10:16 AM
neeman77's Avatar
The hot side is the turbine housing, lol. Glad you got it figured out!
Deception
Jun 23, 2010 12:24 PM
AusS2000
Feb 11, 2010 09:04 PM
s2guru
Jul 31, 2007 04:12 PM
ChefJ
Jun 20, 2007 06:08 PM
macprotege5
Mar 5, 2007 07:58 AM
