Helppppp.....
So frustrated with this car... First I sent the turbo out for a rebuild, got it back and had just put it on. I did some heat cycles and let all the oil burn off.... No problems. I drove it to work which is 10 mins away. On the way back the brake pedal gets really stiff, just like how you try to brake the car with no keys. Also the heat doesn't work anymore.... Any ideas????
Same issue!!! Got my car tuned after being in my garage for 3 months... The blower motor worked fine before I worked on my car. (just installing a turbo kit) and now once it got tuned. the tuner said when he started it, there was no heater as is no air blowing through the vents
Wow, that's deff weird. Does ur turbo have coolant lines? R u sure u don't have any air pockets in ur coolant lines? Also did u have to reposition ur heter valve that sits next to the exhaust side? If so then it might not be opening up and letting the hot coolant in. This happened to me
