herecomesboost build thread (part 2)
Old Oct 7, 2013 | 07:40 AM
  #771
Redline S2K's Avatar
Awesome number man. Car's looking good.
Old Oct 7, 2013 | 08:04 AM
  #772
passmans2kny's Avatar
does the flex fuel sensor allow you to go higher than e85 as well?
Old Oct 7, 2013 | 08:23 AM
  #773
indi00's Avatar
Yes. You can scale to E100.
I think there is no point to go that high. Currently I'm at 25psi on e80 and no signs of detonation. Knock volts less than 1.5 at 20ignition timing. probably can take it to 30 PSI and reduce the timing.
Old Oct 7, 2013 | 09:39 AM
  #774
herecomesboost's Avatar
Thanks!
Not to mention E98 is almost twice (and in some places, three times) the cost of E85. indi00, they've switched to a 'winter blend' in my area. I'm stuck at E75 for the time being.
Old Oct 17, 2013 | 12:56 AM
  #775
riceball777's Avatar
I just bought the flex fuel sensor and harness u listed. What gauge are u running? Is it possible to setup the aem serial gauge to read ethanol content?
Old Oct 17, 2013 | 03:56 AM
  #776
Awesome I'm running the Zeitronix gauge: http://www.zeitronix.com/Products/ECA/ECA.shtml I'm not sure if AEM serial gauge is compatible with the flex sensor.
Old Dec 6, 2013 | 02:32 PM
  #777
Rugby_Guy's Avatar
Thinking about doing an E85 swap (just had a station pick it up near me).
I know I need bigger injectors (2000cc seem to be the consensus)
The question I have is the fuel pump. Is there an "s2000 460lph?" or will any pump pretty much go in there? Also, wiring in a relay is a must to get good voltage to the pump correct?
And are you on a manual boost controller, or having aem control boost?
Old Dec 7, 2013 | 05:08 AM
  #778
I using AEM to control a 3 port MAC solenoid (boost controller). You definitely want to run a relay direct to the battery (using the factory pump wire as the 'trigger' to complete the relay circuit). I don't know if there is a pump kit specific to the S2000; I simply used a universal pump/install kit.
Old Dec 7, 2013 | 10:01 AM
  #779
neeman77's Avatar
AEM gauge cannot display the ethanol content because the output if the sensor is varied ohms rather than voltage.
Old Dec 7, 2013 | 10:29 AM
  #780
I interpreted his question to be referring to AEM (EMS) rather than AEM (TruBoost). Rugby_Guy, can you clarify?
