HG or Not--Gettin Mase'd
I emailed Mase to see what he says and I will go with his decision... thanks for the posts... I just wanted some opinions one what I should do.. Looks like i should go with stock HG but well see..
Originally Posted by vtfo0lio,Sep 12 2009, 03:51 PM
I remember reading a post that Mase did saying he does not prefer a HG. Only stock or built motor.
Either way a blown HeadGasket is not the end of the world. I have seen more 3mm Headgasket cars with higher numbers than Stock HG cars. Rob! drives his car on a Daily basis
Devils advocate................I have yet to see a motor blow on a stock HeadGasket and 12lbs+ of Boost.
Different stroke for different folks.............different methods for different tuners.........
I can tell you what Mase will say... keep the stock HG. My car is currently at Mase's shop getting his turbo kit installed and we talked extensively about 3mm, 2mm and stock headgaskets. Mase prefers to use the stock HG.
FYI - I am running the stock HG and made 405WHP with the small turbo and Mase is putting a bigger turbo on.
