Highest torque numbers
Old Jul 16, 2007 | 04:27 PM
blackey's Avatar
Default Highest torque numbers
I'm thinking of switching my supercharged s2000 to a turbo. FYI- It's a gutted roadrace car. What I'd be interested in knowing is the maximum torque people have seen at 5500rpm on up. This would help me getting out of corners the most. I would run about 8psi max, otherwise I can't cool it at the track unless I race in Alaska.
Bill
Old Jul 16, 2007 | 04:31 PM
slimjim8201's Avatar
Bill
8 psi won't net you ultra high torque numbers. A GT2876R could manage some decent numbers at 8 psi though. You'll want to source the smallest turbo that will provide the HP that you need.
Old Jul 16, 2007 | 07:41 PM
Spec_Ops2087's Avatar
I make 250ft-lbs of torque pretty much consistantly from 4.5k rpms to 9k rpms
Then again I'm boosting double the amount you said.
However, when I was tuned for my 8.5psi run I was making 205 torque with a GT35R which is to inefficent at that boost level. A GT3076 or similar small turbo will have a great torque curve for such large boost.
speedyreds2k
Jul 29, 2007 05:00 PM
s2konroids
May 9, 2007 01:43 AM
doctorcod
Mar 8, 2006 01:27 PM
Chris888jj
Oct 25, 2005 12:14 PM
