hissing sound loss of torque
I was driving after fixing the map clamp yesterday. Pushing the car kinda far but while travelling home I suddenly start hearing a hissing sound and loss of power almost like its hesitating. There is definetly a loss of power but its not throwing a CEL. What could it be? I don't see any leaks anywhere and all of the fluids are at the proper levels?? I didn't realy notice a leak in the exhaust but again haven't had alot of time to look..
Yep. I started in when I got home and the sound, I think is coming from somewhere off of the turbo/charge pipe connection. The charge pipe feels looser and when I started the car and popped the hood I could hear the hissing and when I applied presssure to the top of the charge pipe, pushing it down toward the turbo it went away. I couldn't feel a leak though and the connection seemed tight..
I would but its pouring outside here. Its a difficult charge pipe to tighten down. I am just hoping its not a serious issue or something else. I have had nothing but problems so far with this install and considering it didn't throw a CEL I am trying not to stress out to much.
I willl check everything out whenever I can get a chance to get out there. Its ben raining here forever lol Getting a day off or even getting time off in the daylight is difficult.
I think its coming fro mthe actual housing of the turbo or DP. I can't see any loose bolts but I put pressure on the actual turbo filter and the sound went way then to. It must be underneath it somewhere. Anyone ever have this happen??
I took a listen under the car and was moving the DP around and it sealed up the leak when I pushed it into or toward the turbo housing. I am guessing that a bolt or 2 came loose on the flange. Could this result in a loss of power and torque in the midrange??
