Hks bov for comptech sc
Originally Posted by SIIK2NR,Dec 3 2005, 03:20 AM
It's going to require fabrication in order to get the hks on there. The Godzilla does not require fabrication. The greddys only require an aluminum weld of their flange to the stock aftercooler bypass flange. This allows the 4bolt to work with the 2 bolt.
The SSQ will require welding the stock bypass flange to the actual bov. This can be done for less than $25 and takes about 15 minutes. I would recommend that you buy the flange and weld THAT to the stock bypass flange.
