Hondata K-Pro and boost control
Originally Posted by spiked,Apr 14 2008, 08:44 AM
A friend of mine had his GM solenoid fail on him last week,he would have popped his motor if it were not for his boost cut he had set on his standalone ECU.
So instead of replacing it with the same part that might fail again,he replaced it with something alot better at a cheaper price.I currently have the GM solenoid hooked up,but it's coming out pretty quick and being replaced with the Mac valve I recently purchased,even though there's nothing wrong with the GM part at the moment.
Which solenoid are you using?
I am using the GM boost control solenoid. I ordered this part for my wife's Evo as well.
Originally Posted by JustinC,Apr 14 2008, 07:49 AM
Hondata just released a higher quality solenoid in order to correct the failure that sometimes occurs with the GM product.
Originally Posted by 2QYK4U,Apr 14 2008, 10:58 AM
I saw that...and in fact I think I created a thread about it about a month ago.
BTW, got the Kpro installed and am currently using RSX wideband.
Originally Posted by 2QYK4U,Apr 14 2008, 07:52 AM
I think it is fair to say that all parts are capable of failing at some point. People shouldn't rely on one source of boost control, and thankfully for your friend he had a "back-up".
True,people should not rely on one source of boost control,but when AEM,Hondata,Motec,Apexi,Turbosmart,HDi,ECtune,Gred dy and many more all now use the Mac valve,it's pretty clear why they chose it over the GM part.
You should give the Mac valve a try,it cost less than the GM part and you won't be disappointed by how much better it is over the GM solenoid.
Originally Posted by SC-S2000,Apr 15 2008, 07:05 PM
Thanks for the help I finally figured out that we have to hook up the solenod to a difffernt pin than what the program says. Insted of B21 we are supoose to use A6
