how to activate 2 step on emanage
Originally Posted by SgtB,Nov 2 2008, 04:27 AM
The two step not only limits rpm's but it also adjusts timing. The emu allows 20deg either way. The idea is to get the ignition closer to the exhaust valve opening to get more heat out to the turbo. I haven't gotten IGN ADJ to work, but I think my units are off and for some reason that breaks a lot of things. You probably want a negative number in the ignition field, launch rpm in the start field, and a low number in the v.s. pulse field. All you have to do is apply full throttle at a dead stop and it will activate. Once the emu sees the number of speed sensor pulses you set it releases the cut and timing back to normal. leaving the IGN ADJ field 0 and unchecking it will make it act like basic launch control. I usually run 90% throttle as my setting.
Thanks for the info so far,
Andreas
I can't give you any numbers on the timing. You have to log your timing while in FTL mode and then do the math. You do want it very retarded, and usually after tdc. I'm not an expert on 2 step timing, I just know the principle. The v.s. pulses can be anything you want. I put 5 and it kills it almost as soon as I launch. It's a matter of preference. BTW this is not very good for a catalytic converter, and 2 stepping a stock diff is really asking to waste money.
Ok. Got it working. It's amazing how many things setting your units to F breaks.
The closer you set IGN Adj to -20 the harder it will spool the turbo, but be careful not to overdo it. The start RPM is your launch rpm, and ign cut is red line. BE CAREFUL with ign cut. The emu is always a little off and can over rev your engine. Start around 8500 and work your way up. I know the stock red line is higher, but the emu can drive the engine through the stock cut. I wish it didn't make you use ign cut, but it does. -12 spools my greddy to about 8psi.
Sarge,
just for my understanding. This spooling the turbo effect by retarding the IGN is not gonna work on a supercharger, as they are belt driven, not exhaust gas driven, right?
Thanks for posting your settings, that really helps as well as you explainations!
Andreas
Andreas
Originally Posted by SgtB,Nov 4 2008, 04:34 PM
Yep, turbo only. Glad I could help.
Andreas
Originally Posted by MugenAP2,Sep 2 2008, 08:13 PM
Dude it is easy!!!
A 2 Step
A 2 Step
Now Gone An 2 Step [X4]
Now Get Jiggy With It [X4]
Now Gone An 2 Step
Aye Watch Me 2 Step
Now Can You 2 Step
Like I 2 Step
Watch Me Get Jiggy With It [X4]
Gone 2 Step
[Verse 2:]
Take 2 Steps To The Left
Now Take 2 Steps To The Right
Now Bring It Back
Bring It Back
Hey I Made Ya'll Walk It Out
Everybody 2 Stepping
Now We Finna Turn It Out
Now Here We Go Again
You Already Slow
If You Ain't 2 Stepping
Get Your Shit And Hit The Do'
I'm Shooting At Your Toes
Like A Western
I See You Baby Girl
Sweating Out Your Lil Perm
They Call Me Big Worm
Where My Money At
2 Stepping With My Stacks
Bitch Holla Back
The Oc Is Back
Ya'll Besta Deal With It
And Don't Be Stepping On My Shoes
When I Get Jiggy With It
A 2 Step
A 2 Step
Now Gone An 2 Step
Aye Watch Me 2 Step
Now Can You 2 Step
Like I 2 Step
Gone 2 Step
[Verse 2:]
Now Bring It Back
Bring It Back
You Already Slow
Like A Western
I See You Baby Girl
Where My Money At
Bitch Holla Back
The Oc Is Back
D-style
25
Oct 10, 2006 10:09 PM
