how do you setup failsafe on water meth injection?
Old Feb 10, 2011 | 04:36 AM
purekoryo's Avatar
Default how do you setup failsafe on water meth injection?
i just installed my coolingmist water/meth injection with cmgs which has a failsafe output wire based on low fluid level and min / max flow rate. i am trying to make this as less complicated as possible. how do i exactly wire this up to the aem ems (which pin should i use?) and how do i configure this on the aem tuner to either switch map or turn off the boost solenoid? i am trying to avoid using relays and all that if possible. thanks in advance for all of your help!
gnehc1
Sep 3, 2016 11:31 AM
Ek_Jak
Jun 1, 2011 05:30 PM
purekoryo
Feb 22, 2011 05:11 PM
phils2k
Aug 20, 2009 04:10 PM
s4000k racing
Aug 27, 2007 03:51 AM
