How to fix boost leaks?
Old Jun 14, 2015 | 01:44 PM
beechx1's Avatar
Default How to fix boost leaks?
I have a KW kit with C38-91 blower and the standard KW pulleys on my stock '06 AP2. When I got it tuned, it made 12.5 psi of boost at 8200 rpm. Others with this set up report 15+ psi.
I rigged up a boost testing system and found a couple of leaks. The KW kit comes with worm drive clamps so I bought a T-clamp for the worst leak (the coupler to the intake manifold). With the T-clamp the leak was worse - the coupler bunched up between the T's. I have tightened the worm drive clamps that leaked (not all did) until I am afraid of stripping them but still have some leaking.
How do you guys (especially the guys running higher pressures) seal the couplers - especially the intake manifold coupler?
Old Jun 14, 2015 | 02:15 PM
Totalpkg's Avatar
I use T-clamps for every coupler.
Old Jun 14, 2015 | 02:48 PM
braeden's Avatar
Another member on here said something about using hair spray on the openings of the silicone hoses, apparently works quite well
Old Jun 14, 2015 | 06:02 PM
Habitforming's Avatar
the coupler that goes on the throttle body is the wrong size. Kw ships a straight 3" coupler, but you need a 3-2.75" reducer instead. Siliconeintakes.com
Also use t bolt clamps everywhere. I have a thread on which sizes are needed here in the fi forum. On my phone, so hard to find and link it.
Old Jun 14, 2015 | 06:09 PM
The Machine's Avatar
This is straight from Habitforming's thread:
T Bolt Clamps
These are the clamps I used and their sources. Note that you won't be able to get a T bolt clamp for the air filter, as the clamping surface on it is too narrow - not a problem since it doesn't see boost. I also had to use a worm screw clamp for the valve cover vent hose attachment to the intake elbow. Again the landing was too narrow for the T bolt style that I bought.
Siliconeintakes.com
3.0" x 6 (intake elbow x2, intercooler x2, 3rd charge pipe x2)
2.75" x 1 (throttle body)
2.5" x 5 (Rotrex x1, 1st charge pipe x2, 2nd charge pipe x2)
Silicone reducer, 3.0" to 2.75" (3rd charge pipe to throttle body)
McMaster.com
1 7/32 to 1 5/16" x 4 (hoses for bypass valve), part # 5462K48
1 5/16 to 1 7/16" x 1 (bottom of intake elbow where bypass valve hose attaches), part # 5462K49
Hope this helps some of you
Old Jun 14, 2015 | 06:13 PM
yeah what he said (that I said)
Old Jun 14, 2015 | 06:34 PM
06S2k07Si's Avatar
Good clamps here...I use these on my setup. All stainless steel.
http://www.ebay.com/itm/261479992740
Old Jun 14, 2015 | 08:00 PM
beechx1's Avatar
When I tried both a worm clamp and a T-clamp on the same joint, I found that the worm clamp leaked less. I was surprised at this given what I read on this forum. But the test data was the test data. When I examined what was happening, I found that the T-clamps clamp well from one T around to the other T but leave a clamping gap for the short distance between the Ts. This is where it was leaking. The worm clamps clamp all the way around.
I have ordered a 3"-2.75" reducer to see if that helps at the intake manifold.
SilverstonedAP2
Mar 27, 2012 06:31 PM
deathsled
Dec 8, 2009 08:06 PM
moonwalker
Nov 2, 2008 09:28 PM
Phillie
Dec 27, 2006 09:51 AM
folex187
Aug 16, 2005 01:22 AM
